Thread: 2006 TDI Engine Thud Noise
  1. 2006 TDI Engine Thud Noise
    When you are driving along or stationary, if you just tap/blip the accelerator pedal there is like a thud (or light hollow bump) coming from the engine. Its not the suspension or clutch, as i say it also happens when stationary. the noise is hard to describe, it is only for a split second as you just touch the accelerator. Any ideas? It doesn't sound anything major, but i'm no mechanic.
  2. Re: 2006 TDI Engine Thud Noise
    Oct 2007
    Woking
    It's the engine rocking in it's mounts due to the sudden torque - perfectly normal.
    The solution is not to blip the throttle........
  3. Re: 2006 TDI Engine Thud Noise
    but if you floor it, then it doesn't happen
  4. Re: 2006 TDI Engine Thud Noise
    Oct 2007
    Woking
    Because when you floor it, there's not a sudden wave of torque, immediately followed by it subsiding, so the engine doesn't rock back and forth, thus no thud.......
  5. Re: 2006 TDI Engine Thud Noise
    Flywheel, very coomon problem on TDI engines.
    There is a service action on replaceing the flywheel.
    Go to authorised dealer to inspect it.
    I have to many problems with this. Fix this problem now or wait to get even worst, almost you cant drive the vehicle.
  6. Re: 2006 TDI Engine Thud Noise
    I've just realised sorry, the car is actually a SDI, will this still be the case with the flywheel? Is the flywheel anything to do with the clutch?
  1. 1z engine noise
    By eddiemax28 in forum 80 - 90
    Last Post: 27-01-2008, 02:14 PM
  2. Passat B6 TDi 140 estate 2006 Gearbox noise
    By steve46 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2008, 12:30 AM
  3. engine noise!
    By grayman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2007, 01:12 PM
  4. Thud when releasing clutch pedal
    By Mark A in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 07:47 PM
  5. Noise from engine - help
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 03:56 PM
