Thread: petrol cap jammed shut!!!
  1. Angry petrol cap jammed shut!!!
    Aug 2007
    kent
    i went to get petrol today, only to find the petrol flip cap jammed shut. the button inside the car just wouldnt release it.
    i am so nearly out of petrol and need to fill it asap.
    shall i just force it open or has any1 got any ideas.
    any info would be great!
    vw passat estate 1.8t 1999
  2. Re: petrol cap jammed shut!!!
    Hi, If you remove the boot carpet behind the fuel filler, you will see a motor which controls your fuel filler door. Unscrew the motor (2 screws) and manually pull the rod. THis should release the fuel filler door ( based on a Passat 1999 model saloon ) as it happened to me too.
  3. Re: petrol cap jammed shut!!!
    i have the opposite problem, I own a passat 2.0 53 reg, the problem is - the fuel filler door won't close and the trunk door won't close. This appears to have started after I had my car washed with a power spray, I dont know if that would be connected in any way, anyone out there got any ideas? Thanks, andy h
  4. Re: petrol cap jammed shut!!!
    Please keep away from pressure sprays they can cause a lot of damage especially if the are aimed near door and boot locks and find their way into your electrics.
    Its a shame that some people don't hand wash their own ar anymore.
    MrG
  5. Re: petrol cap jammed shut!!!
    Tyldesley, Manchester, UK
    Quote Originally Posted by MrG View Post
    MrG
    That is a comment I would expect to see on an Italian [old] car forum . Though I am sure you do have a point
    One German, Two Italian.
  6. Re: petrol cap jammed shut!!!
    thanks guys for the comments, i'm a wee bit wiser now.
  1. how to open jammed lock to fix it!
    By sensible in forum Chat - Anything with wheels
    Last Post: 23-09-2010, 08:50 AM
  2. Rear passenger door jammed shut
    By oa5599 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-12-2008, 09:30 PM
  3. Key Jammed in door
    By joanne in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2008, 08:57 PM
  4. The bonnet is jammed!!
    By kian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-06-2007, 12:26 PM
  5. Jammed windows B5
    By neilfc in forum Passat - Archive Topics
    Last Post: 10-06-2006, 09:04 PM
