Yep you read it right my sunroof has started letting water in, it sit in the plastic cover over the interior lights and in the cover that gives you access to the sunroof motor. Roof hadn't worked for a while but on my way home last night it completly opened all by it's self and refused to close, pulled over and managed to manually crank it closed. I've got it booked in for next week so I was going to take the fuse out till then, but I have no idea which fuse to pull? If someone could tell me I would be very grateful,
Thanks in advance Ray
Passat 1999 se
1.8 4 door
manual
