Thread: cooling system
  1. cooling system
    hi all can anybody tell me the best way to bleed the cooling system on a passat 130 tdi its an 02 thanks bill
  2. Re: cooling system
    Hi Loosen the coolant hose on heat exchanger and pull back the hose sufficiently so that the bleeder hole is no longer sealed by the connection.
    ‒ Top up coolant until it flows out of the bleeder hole in coolant hose .
  3. Re: cooling system
    Quote Originally Posted by kenney View Post
    hi kenney where is the heat exchanger is it the aluminium block just below the oil filter tube thanks bill
  4. Re: cooling system
    Hi The hoses to the heat exchanger (matrix) run from the rear of the engine to the plenium chamber.
  5. Re: cooling system
    7 Post(s)
    Topping up the header is not enough.
    You need to undo it and raise so that it is higher than the bleed hole. As soon as you get coolant coming out of the bleed hole, whilst still hold the header tank up, slide the hose back on so you don't get air drawn back in.
  6. Re: cooling system
    Quote Originally Posted by BigCol View Post
    thanks lads for the advice ill give that a go cheers bill
  1. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  2. A3 Cooling Fan Problem
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 10-10-2007, 09:05 PM
  3. No pressure in cooling system
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2007, 06:48 PM
  4. cooling fan
    By mike d in forum The Commercial Range
    Last Post: 02-07-2007, 11:47 AM
  5. Mk3 golf 2.0 gti / air in cooling system
    By Happy_Trucker in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2006, 01:26 AM
