Thread: Removing Avant rear suspension
  1. Removing Avant rear suspension
    I intend to replace my rear shocks and the rubber housing as they make a really annoying noise. I have managed to remoev the spring with the shock but had to stop as I was unable to remove the shcok. There is a 17mm bolt with a nut in the middle. My question is, do I need a special Audi tool or is there a way of removing this?
    If anyone has any other general tips on this subject I would be very glad to hear them.
  2. Re: Removing Avant rear suspension
    london/ UK
    Do yo KNOW wt are you doing ? That spring will shoot like a bullet if you remove that nut !!!! Get some spring clamps to compress the spring otherwise you could get hurt by attempting to undo them shocks !
  3. Re: Removing Avant rear suspension
    Yes I have spring clamps and am well aware of the pressure that the spring is under. Do you have any ideas on the tool required?
    Many Thanks
    Quote Originally Posted by adamss24 View Post
  1. Removing rear passenger door glass
    By proworldinc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2007, 01:41 PM
  2. Audi A4 1.8T removing bottom suspension arms
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2007, 10:15 PM
  3. Removing clamp bolt from front suspension
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-07-2007, 11:37 PM
  4. Audi A4 1.8T removing bottom suspension arms
    By rhencullen1989 in forum Chat - Anything with wheels
    Last Post: 09-07-2007, 06:43 PM
  5. Suspension for new A6 Avant
    By Richard Charles in forum New Member Introductions
    Last Post: 12-03-2007, 11:50 PM
