Thread: cambelt change interval on 110 gt tdi?
Results 1 to 10 of 11
  1. cambelt change interval on 110 gt tdi?
    May 2007
    As above, can anybody shed any light on the belt change interval on the 1998 110 gt tdi AHF engine.. (last one recorded was 70k and the car is on 117k now. cheers.
  2. Re: cambelt change interval on 110 gt tdi?
    134 Post(s)
    2015 Post(s)
    Every 60K or 4 years.
  3. Re: cambelt change interval on 110 gt tdi?
    May 2007
    Quote Originally Posted by andy-b View Post
    Cheers Crasher!
  4. Re: cambelt change interval on 110 gt tdi?
    My golf is due for a new timing -belt. Currently on 118k, i will be getting the full timing -belt kit, which includes the water pump and tensioners. I was wondering how much it would cost for parts/labour. my local garage (which is not a VW specialists) is asking for £220. Is that a fair price??
  5. Re: cambelt change interval on 110 gt tdi?
    134 Post(s)
    2015 Post(s)
    What is your Golf?
  6. Re: cambelt change interval on 110 gt tdi?
    What is your Golf?
    Oops sorry, Golf s 1.6 16V 2000W, hope it helps.
    VW Golf S 1.6 16V 2000W 100bhp
  7. Re: cambelt change interval on 110 gt tdi?
    134 Post(s)
    2015 Post(s)
    That should be an AUS engine and the interval is still 4 years or 60k as far as I am concerned. They are not particularly easy to do as they have two belts, one to drive the inlet cam and one to drive the exhaust cam form the inlet cam. One thing on that engine, please only use 99RON octane fuel, i.e. Shell V power or Tesco 99, otherwise you will burn out an exhaust valve but 97RON is an acceptable alternative. If you look inside your fuel filler cap it says Min octane 98/95 RON and that means normal 95RON fuel in exceptional circumstances only.
  8. Re: cambelt change interval on 110 gt tdi?
    I usually fill me tank up at Asda. Not sure about the RON octane though???
    Crasher i have a AUS engine deffinately, but could u expand a bit more on the fuel/octane bit.
  9. Re: cambelt change interval on 110 gt tdi?
    134 Post(s)
    2015 Post(s)
    There are a few links on this site about this problem. If you look inside your fuel filler flap you will see a sticker. On this it will say something like minimum octane 98/95. What this means is the fuel you put in must be at least 95RON octane (what you put in at Asda) but preferably 98RON which is currently unavailable in the UK. What is available is 97RON (BP Ultimate, Texaco Exeliwotsit), Esso Supreme etc) or 99RON and that is only available from Tesco and Shell as V Power. VW's official view on this is "98 unleaded (in exceptional circumstances min. 95 RON, however with reduced performance)" BUT the 105PS engines that need this fuel (not just the AUS but also the many other versions) are suffering from exhaust valve seat burning problems at around 60K miles.
  10. Re: cambelt change interval on 110 gt tdi?
    Thank you very much , will be filling up @ texaco from now on.
  1. Cambelt service interval
    By Alfonzo in forum Golf MK3 - 1993 - 1999
    Last Post: 29-06-2008, 05:46 PM
  2. Opinion on Cambelt change interval for a 1.8T Petrol MK2
    By The Hofmeister in forum Alhambra
    Last Post: 04-10-2007, 12:12 PM
  3. Golf 2 litre cambelt change interval
    By PJS in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 08:10 PM
  4. cambelt change interval
    By jezzaxt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-09-2006, 10:09 AM
  5. Correct cambelt change interval for 1998 Passat?
    By cmman127 in forum Passat - Archive Topics
    Last Post: 02-03-2006, 10:13 AM
