Thread: Bleeding fuel
  1. Bleeding fuel
    Oct 2007
    Changed the injector pump on my v6 and i cant get it to start
    Can see a bubble of air in the clear pipe and i keep turning it over but the cars complaining about low oil pressure if i keep cranking it
    Am i doing something wrong?
    I stuck the belt back on the injector pump as close to where it was originally as i could, will it make a difference if its not spot on?
    I left all the injectors cracked off and all but one bleed fuel everywhere so done them all back up but it just wont fire and i still have the air bubble.
    Help please im stuck
  2. Re: Bleeding fuel
    Oct 2007
    Hi yes these engines are hard to start if the pump is not adjusted properly
  3. Re: Bleeding fuel
    Oct 2007
    can anyone point me in the direction of how to time the pump?
    Looks like the in tank pump has failed as well
  4. Re: Bleeding fuel
    Oct 2007
    Hi iam afraid this is a highly complicated job,if you do not have the know how ,not to mention the proper tools needed,and not least, vehicles from model year 2002 the new injection pump must be adapted to immobilizer
  5. Re: Bleeding fuel
    Oct 2007
    looks like i need to set TDC on the V6 then set TDC on the pump and go from there, not too difficult if you can find the timing marks.. any idea where they are on the engine?
  1. Bleeding the heater
    By FLHRCI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2008, 06:56 PM
  2. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  3. bleeding brakes!!!!!
    By strawboy in forum New Member Introductions
    Last Post: 02-10-2007, 08:27 PM
  4. a4 tdi bleeding the fuel system HELP
    By sim2101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-07-2007, 01:43 PM
  5. diesel bleeding A6
    By niall campbell in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-07-2007, 05:03 PM
