Thread: LT 35 Sdi losing water
  1. LT 35 Sdi losing water
    Hello. i'm losing water externally, dribbling onto the front of sump pan from the engine ? Theres no exhaust smoke, no bubbles in header tank, and no water in the oil, or oil in the water. It did overheat through lack of water a couple of weeks ago, if that happens could it be pump seals or worse?
  2. Re: LT 35 Sdi losing water
    london/ UK
    Yeah, most likely is the water pump. If it overheated, chances are that the cylinder head might be warped, but as diesels are built stronger than the petrol engines, the head might be ok ! Replace the water pump, cambelt and all belts/tensioners while you at it, and take it from there !
  1. Golf tdi 115 bhp (1999)-losing water, help!
    By johne in forum Golf MK4 - 1999 - 2004
    Last Post: 14-01-2008, 11:24 PM
  2. MK3 TD (AAZ) Losing Water
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 06-01-2008, 06:04 PM
  3. Losing water....
    By mariacarroll in forum Audi A3 - Archive Topics
    Last Post: 15-09-2007, 03:33 PM
  4. Golf 1.9 GTTDi losing water
    By richiek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 10:35 PM
  5. Mk 4 Golf TDI Estate losing water
    By Stevie Boy in forum Archive posts
    Last Post: 28-02-2007, 07:42 PM
