Thread: Anyone else's standard radio totally rubbish?
  1. Anyone else's standard radio totally rubbish?
    meathead Guest
    Mine is! Both FM and AM are pathetic.
    I get around this by using a tape adaptor for my Ipod, but I'd really like to solve the problem. I've tried boosters, a new radio unit (A JVC CD player) and that's just the same....
    Anyone in the same boat?
  2. Re: Anyone else's standard radio totally rubbish?
    Dec 2006
    Wiltshire
    If another unit is as bad and you used the correct aerial adapters then your Aerial is almost certainly at fault. They are known to fail on the Mk IV.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: Anyone else's standard radio totally rubbish?
    meathead Guest
    Aha! Thanks for that. I'll steal, ahem, borrow one from my mates golf!
  4. Re: Anyone else's standard radio totally rubbish?
    Inverness - Highlands
    Anyone know where to get good quality replacement aerials other than *******?
  5. Re: Anyone else's standard radio totally rubbish?
    Dec 2006
    Wiltshire
    Bosch make a decent replacement, but be aware that the aerial cable might need an adapter. I seem to remember that the factory aerial doesn't use a normal aerial extension connector.
    Have a look at bluespot.co.uk, I think they stock them.
  6. Re: Anyone else's standard radio totally rubbish?
    meathead Guest
    Plenty of cars being broken on ebay!
  7. Re: Anyone else's standard radio totally rubbish?
    This might be helpful:
    I recently bought an 02 Golf 4 GTTDi 130 with standard radio and cd (my first VW and I luv it !)
    I found I could not recieve AM radio signals at all
    After discussions with VW dealer they suggested the aerial was probably faulty so I bought a new one £45 !!! but it still didn't work
    I eventually found out that the VW roof aerials on Golfs have amplifiers in them and require a 12V power supply to work
    On the standard VW radio this 12V is cunningly supplied from the radio via the centre core of the aerial lead
    Check that the radio is outputting +12V from the aerial socket when switched on before looking at new aerials
    If you want to fit another manufacturers radio you will need a PC5-90 roof aerial adaptor if the new radio does not output the 12V
    Rgds
  1. Rubbish Radio Reception
    By andrewhunt37 in forum Bora - 1998 - 2005
    Last Post: 06-01-2008, 09:48 AM
  2. totally mad
    By mbronsell in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2007, 09:39 PM
  3. Tyres totally scrubbed!!
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2007, 12:48 PM
  4. Standard Radio V Bluetooth
    By Spiceman in forum Passat - Archive Topics
    Last Post: 20-07-2007, 10:40 AM
  5. Replace standard radio unit
    By alpappy in forum Eos
    Last Post: 24-02-2007, 08:39 PM
