Thread: Reprogramming the remote control of 2004 PASSAT
  1. Reprogramming the remote control of 2004 PASSAT
    Jan 2008
    I found this picture, but I am confusing about the step 3. The button I need to press is on the first key in the ignition or the second one?
  2. Re: Reprogramming the remote control of 2004 PASSAT
    Jun 2007
    ireland
    you must press the button on the key fob you used to lock door
  3. Re: Reprogramming the remote control of 2004 PASSAT
    Jan 2008
    This method does not work for my remote control. I tried for several times, but when I pressed the unlock button the horn will sound for a few minutes and the red light was flickering.
  4. Re: Reprogramming the remote control of 2004 PASSAT
    Jun 2007
    ireland
    To Do This You Must Have 2 Keyfobs,recheck You Have Fitted Battery Correctly To Fob.......switch On Ignition With Working Keyfob,use Non Working Key To Lock D/s Door,with Remote Press Unlock Once Beep Will Sound.....wait 6 Seconds...press Unlock Again To Activate Code. I Have Done This A Few Times Without Any Trouble ......try Again
  5. Re: Reprogramming the remote control of 2004 PASSAT
    Jan 2008
    Quote Originally Posted by paulp View Post
    Unfortunately, this method does not work for my remote control too...... I have fitted battery correctly. The beep did not sound when I pressed Unlock. Just the small red LED was flickering. When I pressed the Unlock until the LED stopped flickering, the door opened, but the beep sounded for a long time and the LED was flickering again.....
  6. Re: Reprogramming the remote control of 2004 PASSAT
    Oct 2006
    Thank you...This just worked on our MK 4 Golf
  7. Re: Reprogramming the remote control of 2004 PASSAT
    Dec 2007
    Thankyou very much for this info, I have just re synced a key fob to my gt tdi 150 (2003).
  1. How do I reset the car alarm without a remote control?
    By Snowqueen in forum Golf MK3 - 1993 - 1999
    Last Post: 01-07-2011, 08:51 AM
  2. 2004 PASSAT remote programme
    By archibald_999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2008, 10:50 PM
  3. Comfort Control Module - Polo 2004
    By lwotton in forum Polo - Derby - Lupo - Fox
    Last Post: 25-01-2008, 04:19 PM
  4. Remote control outdoor light????
    By bonerp in forum Chat - Completely Off Topic
    Last Post: 10-10-2007, 10:03 PM
  5. remote control
    By dataseeker in forum Audi A3 - Archive Topics
    Last Post: 25-09-2007, 08:09 AM
