Thread: Erratic engine idle when warm
  1. Erratic engine idle when warm
    Oct 2006
    Hiya All
    Just bout a 99 T reg Bora 1.6 8v. When the engine is warm the idle gets very erratic and seems to bounce too causing the car to sometimes stall. Garage have cleaned out the throttle system with cleaner and the effect was it now idles too high and when warm the needle still bounces very eratically. Anyone any ideas ? First time owner of a VW so anyone bounce some idea's?
    cheers
    ck
    london/ UK
    Disconect the battery, switch lights on ond off to clear static and reconect after a few minutes. The basic settings will be wipped out in the ecu and it will start learning the new settings. It takes about two days to do that so take the car for a normal drive and also give it somme stick on the motorway putting the engine trough all loads. Also check idle speed actuator(electronic=no adjustments), injectors, fuel pressure regulator,MAF, coolant temp sensor, crankshaft/camshaft position sensors, lambda sensor. Also see if there are any fault codes set in the memory and make a note and post them on the forum.
  3. Cheers
    Oct 2006
    Hiya thanx for that due to go down my local garage tomorow will pass that on to them.
    thanx again craig
  1. ADR 20v engine noisy tapping at warm idle
    By Mike65 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 01:39 PM
  2. erratic idle and loss of power
    By anya in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-02-2007, 10:16 PM
  3. Audi A4 1.9 TDI 130 Erratic idle
    By eldottore in forum New Member Introductions
    Last Post: 27-11-2006, 09:52 PM
  4. idle erratic coupe 2.0l
    By pubuk in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-10-2006, 06:30 PM
  5. MK2 Golf Gti idle erratic
    By Dave Gibson in forum Golf MK2 - 1984 - 1992
    Last Post: 04-04-2006, 01:03 PM
