Thread: Audi Quattro - parts needed
  1. Audi Quattro - parts needed
    Feb 2007
    Hello folks,
    I'm living in Holland and my 1988 Coupe Quattro has just failed the Dutch MOT. The local garage has quoted an extorionate price to do the work to get it through. Needs a complete exhaust system as some muppet fitted an after market system which leaks everywhere. Also need a suspension mount and lower ball joints. A few other minor things like bulbs. The estimated cost is 1,500 euros. Was told it's about 10hours work. Obviously the fella i spoke to doesn't want to do the work - so i'm thinking of driving it to the UK to get it sorted. Can anyone recommend a decent Audi specialist in the South East - suffolk, cambs or essex? Plus does anyone know how much the above parts should cost?
    Raz
  2. Re: Audi Quattro - parts needed
    Gwent
    He must be a slow worker, I could do that lot in less than 10 hours without garage facilities.
    The top mounts are approx £12 and I think your balljoint might be the rarer two bolt type, but even so should not be more than say £30?
    You could shop around for the exhaust, custom autocraft have a range in stainless that look nice I have no experience of them myself
    http://sites.internet.lu/folders/cus...craft/main.htm
    or you could try eurocarparts/GSF/Vagparts etc, see if you can find a genuine/o.e. supplier system.
    Sorry I don't know of anywhere in the south east.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Audi Quattro - parts needed
    Feb 2007
    Cheers Scotty,
    Just as i thought then - the geezer in my local garage here just can't be bothered to do the work. Think i'll definitely bring car home to UK. There's no way i'm gonna give anyone here over a grand to do the work. Although i was told that i need to have the CO emissions sorted out and that could be a bit pricey.
  4. Re: Audi Quattro - parts needed
    Gwent
    Which engine code is this?
  5. Re: Audi Quattro - parts needed
    Feb 2007
    Engine code. Not sure what you mean?
    It's on the paper work as 2,3 20v U9.
    The guy said the U9 represents the electronic fuel injection - is that what you meant?
  6. Re: Audi Quattro - parts needed
    Gwent
    If it's a 2.3 20v it should be a 7A engine code, I just wondered which engine type you had. If the plugs, leads, airfilter etc are healthy, the emissions could be due to an ECU temp sender problem, lambda probe or maybe maf sensor problem? These should show up on a fault code read, you could do this yourself with a home made reader:
    http://20v.org/tools.htm#VAG1115
    http://20v.org/fault.htm
    Maybe this advice could help?
    http://20v.org/emissions.htm
  1. Parts needed for a service?
    By Sloggs in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2008, 03:22 PM
  2. Used Parts Audi 80 Quattro
    By rudivisser in forum 80 - 90
    Last Post: 01-02-2008, 02:16 PM
  3. audi coupe quattro 1989 parts
    By sox in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-08-2007, 09:14 PM
  4. Audi 90 quattro - exhaust parts
    By RJS_90q in forum 80 - 90
    Last Post: 07-01-2007, 09:14 PM
