Thread: Drive belt noise
  1. Drive belt noise
    neileg Guest
    I've got a 1996 1.9 non turbo diesel, 1Y engine. Shortly after I bought it, about a year ago, the ribbed drive belt that serves the alternater and water pump started slipping. I renewed the belt with a cheap one from my local accessory shop. A couple of weeks ago, the belt was noisy again so I replaced it with a belt from Halfords. Guess what - it's started to squeak when cold, though it quietens down as soon as it warms a bit. Any ideas?
  2. Re: Drive belt noise
    neileg Guest
    Now squealing quite a bit on startup. The tensioner on this engine is a spring on the alternator mounting. Could this have weakened?
  3. Re: Drive belt noise
    Quote Originally Posted by neileg View Post
    You need to change the tensioners and rollers mate. You should always do this when changing the belt, otherwise you risk the new belt failing. Sometimes, the auxillary belt coming off, can take the timing belt off, and thats a whole load of trouble you don't want for the bother of a few quid
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  1. Auxiliary drive belt on Touran?
    By pittman in forum Touran - Sharan - Caravelle
    Last Post: 14-01-2008, 10:25 AM
  2. Aux drive belt on 1.8T
    By GavinT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2007, 12:47 AM
  3. Auxilliary drive belt catastrophe
    By Malcolm K in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2007, 12:16 PM
  4. Serpentine Drive Belt
    By colifeashots in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2007, 01:21 PM
  5. Passat TDI auxillary drive belt tensioner
    By vincentbob in forum Passat - Archive Topics
    Last Post: 19-01-2007, 04:54 PM
