Thread: changing track rod end ball joint
Results 1 to 8 of 8
  1. changing track rod end ball joint
    Can any one advise me. I need to change my track rod end ball joint. Have removed the adjuster bolt and undone the pinch bolt nut, what I am not sure about is do I need to remove the pinch bolt as it seem to be jammed. Help
  2. Re: changing track rod end ball joint
    Feb 2007
    Nottingham
    Quote Originally Posted by waynetdi130 View Post
    When you say the pinch bolt do you mean the threaded bolt at the end of the track rod that connects with the hub? If so you will need a ball joint splitter to drive it upwards as the shaft is conical (or hit it with a hammer if you're a bit of a pikey)
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  3. Re: changing track rod end ball joint
    May 2009
    cardiff
    I heated it up (the housing not the bolt) and then hit it with a lug hammer after refitting the nut until it was in line with the pinch bolt.
  4. Re: changing track rod end ball joint
    Jan 2010
    Thatcham
    Hello ... did you ever manage to remove the pinch nut bolt? Does it need to be removed? I am trying to change the track rod end ball joint ... I think I have the same problem you had. It looks like I somehow need to get the pinch nut bolt out but it's proving difficult. Any tips??
  5. Re: changing track rod end ball joint
    Feb 2007
    Nottingham
    Are you referring to the bolt in the picture below? I.e. the track rod end bolt?
    These often get rusted and sieze and you will struggle to remove them, you may need to cut through the bolt&nut underneath with an angle grinder or similar and replace the whole track rod end
  6. Re: changing track rod end ball joint
    Jan 2010
    Thatcham
    Thanks for getting back to me. I was actually referring to the pinch bolt in the housing that the track rod end fits into. the bolt had seized in the housing... I managed to get it out using a subtle blend of cunning and a dirty great hammer!!
    Thanks again.
  7. Re: changing track rod end ball joint
    Jun 2006
    UK, Mids
    You are all talking about different designs of track rod end
    Audi A8 - 2015 - 3.0TDI
  8. Re: changing track rod end ball joint
    Mar 2008
    High Wycombe
    Quote Originally Posted by snapdragon View Post
    They were talking about different designs four months ago.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Changing cv joint / gaiter
    By MartinPCWard in forum Passat - Archive Topics
    Last Post: 07-01-2008, 08:13 PM
  2. TOW BALL for BOSAL towbar
    By passat57 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 05-07-2007, 01:26 PM
  3. Cost of Replacing A4 Front Suspension Upper Ball Joints
    By bigcrags in forum Audi A4 - Archive Topics
    Last Post: 28-02-2007, 03:37 PM
  4. audi 80 ball joint replacement
    By rockbadger69 in forum 80 - 90
    Last Post: 26-01-2007, 07:36 PM
  5. Audi A4 Ball Joint failure
    By Tim in forum Chat - Completely Off Topic
    Last Post: 03-11-2006, 10:09 PM
