Thread: thermostat Audi 2002
  1. thermostat Audi 2002
    Jan 2008
    How do I change my thermostat in my 2002 Audi A4?
  2. Re: thermostat Audi 2002
    Oct 2007
    hoo, kent
    just had mine replaced, it is a tricky job,
    no problem for a good mechanic though,
    make sure you change the whole thing, housing as well,
    as it contains another sensor,as if there was;nt enough of them,
    once changed all underheating problems should be solved, mine were.
  3. Re: thermostat Audi 2002
    Jan 2008
    Thanks for the help. Turns out it was my waterpump that needed replacing - my thermostat was fine...
  4. Re: thermostat Audi 2002
    Sep 2007
    Quote Originally Posted by paul bish View Post
    Hi, sorry dont mean to crash this post but what do you mean by 'all underheating problems'?
    the problem im having is if i turn my climate control to normal temp 21oC i get cold air unless i turn it up to 24oC which gives me perfect cabin temp.
  5. Re: thermostat Audi 2002
    Oct 2007
    hoo, kent
    good, hope you had a good look at old water pump.
  6. Re: thermostat Audi 2002
    Oct 2007
    hoo, kent
    if engine does not run at 90 degrees air con temps will be affected
  1. coding ESP audi a4 2002
    By pati in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2008, 02:32 AM
  2. Audi A4 Tdi Diesel 2002
    By Mick Singh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-10-2007, 06:40 PM
  3. Audi A4 tdi sport 2002
    By robert67 in forum New Member Introductions
    Last Post: 02-09-2007, 09:03 PM
  4. Audi A4 TDI 2002 130 Computer Qstn
    By Blackadder in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2007, 09:10 AM
  5. Audi A6 1.9 tdi 2002 Boot won't shut
    By stones in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2007, 08:46 AM
