Thread: 1z engine noise
Results 11 to 20 of 22
  1. Re: 1z engine noise
    Ebbw Vale
    i was just thinking could it be a blocked injecter????
    audi 80 1.9tdi 1z estate
  2. Re: 1z engine noise
    Sep 2007
    yorkshire
    Are you getting ten ton of soot from d tailpipe.
    Crasher, you do a wicked ALI G impersonation.
    2003 AUDI AVANT SPORT TDI
  3. Re: 1z engine noise
    Ebbw Vale
    theres no smoke at all coming from the tailpipe
  4. Re: 1z engine noise
    Sep 2007
    yorkshire
    If no smoke at all! I would disregard the pump and/or timing and the injectors. Sounds like an internal engine failure. (but could be something else) Do a recording of the noise and post it on www.youtube.com and the link to it on here.
  5. Re: 1z engine noise
    Ebbw Vale
    kk lyk i will do
  6. Re: 1z engine noise
    Ebbw Vale
    rite heres tha youtude link http://www.youtube.com/watch?v=IXBqBYk6Tms
  7. Re: 1z engine noise
    #17
    131 Post(s)
    1976 Post(s)
    Dat ist timing man, oo de dood doin de rap on de mike?
  8. Re: 1z engine noise
    #18
    Ebbw Vale
    do u knw wot it is???
  9. Re: 1z engine noise
    #19
    131 Post(s)
    1976 Post(s)
    You need to re-check your cam timing with a cam alignment plate and pump sprocket pin against the flywheel 0 mark. If this is OK, then check the Commencement Of Injection with VAG-COM. Do you have VAG-COM?
  10. Re: 1z engine noise
    #20
    Ebbw Vale
    wot is tha VAG_CAM. all the timing is done fine lyk but donno about the pump timing
  1. noise from engine.
    By amphiltis in forum Golf MK3 - 1993 - 1999
    Last Post: 05-09-2013, 07:46 PM
  2. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  3. engine noise!
    By grayman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2007, 01:12 PM
  4. Noise from engine - help
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 03:56 PM
  5. Engine choking, noise
    By andrew00011 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2007, 06:10 PM
