Thread: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
Results 1 to 10 of 39
  1. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    135 Post(s)
    2026 Post(s)
    If you were to put a multimeter on the battery and start the engine without revving it, you would see approx 12 volts. Increase the revs and at approx 2500rpm the voltage would suddenly jump to approx 13.8 volts and this is a symptom associated with problems in the alternator warning light circuit.
  2. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    Oct 2007
    Crasher Thanks for the info, the car isn't here at the moment to check but what is the cure? I have been advised that the alternator has a fault but could the ignition circuit/switch/warning light also be at fault?
  3. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    135 Post(s)
    2026 Post(s)
    You should check the continuity of the wiring between the instruments and the alternator which doesn’t take too long to do. The wiring varies a lot, can you PM me the cars reg so I can check the specific layout for that car and your email address if you want the wiring diagram.
  4. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    Oct 2007
    Crasher cannot send pm as I haven't got enough posts!! Can you pm me your email address and I will send info by return
  5. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    135 Post(s)
    2026 Post(s)
    Consider it done, sent you an email.
  6. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    Jan 2008
    Hi, I have 2002 1.9TDI polo with the same problems, however the the plug onto the alternator has voltage to it. It just wont power up the alternator. As soon as i bridge the live to the plug on the alternator it powers up.
    There is no battery light on the dash.
    Any suggestions???
    Thanks.
  7. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    135 Post(s)
    2026 Post(s)
    Does the alternator charge?
  1. 1.2 Polo 2002 - power steering fault
    By vw1992 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-10-2009, 08:51 AM
  2. Polo 2002, 1.2 ABS system
    By weekendsession in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 01:58 PM
  3. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  4. 2002 Polo synchromesh failure
    By Bossy in forum Polo - Derby - Lupo - Fox
    Last Post: 14-11-2007, 06:46 PM
  5. Polo dash lights
    By FingerPrint in forum Polo - Derby - Lupo - Fox
    Last Post: 12-11-2007, 07:46 PM
