Thread: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
  1. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #31
    Hi the wire runs from the alternator to a 2-pin connector, near the starter,and to pin 1 on an 11-pin connector, (white), on left of the bulkhead ,from there to pin 9 on an 18-pin connector, (brown) on the OB supply unit.
  2. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #32
    Thanks, thats a great help. I will test the circuit between the points now on that circuit.
  3. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #33
    Hi Kenney, could you tell me whereabouts the OB Unit is. I have managed to find a broken wire under the starter and have joined that. All was good the battery light came on and the car started and charged. Turned it off and then back on and no battery light. After a few turns of the ignition it appeared again. Switched off and it then took another few clicks of the ignition before it came back on again... WEird i have to say.
    I have a wiring diagram, thanks Crasher however that does not show me where the wiring goes after connection 27 on the diagram.
    Any help guys would be appreciated. I thought i was there and i nearly could be.
    Thanks.....
  4. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #34
    1836 Post(s)
    Between the On Board Power supply and the dash the light is CAN BUS controlled.
  5. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #35
    Thanks Crasher. Do you know whereabouts behind the dash the OB supply is located. I can run a test from it then. Is it possible that supply will make the light intermittent.
  6. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #36
    1836 Post(s)
    It is directly above your right foot, clip lying horizontal, into the wiring, fuse, relay etc carrier. A fault code read of the system would make sense.
  7. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #37
    The system only shows the one fault code which is p1503 Load signal from Alternator Term. DF Range/performance/Incorrect Signal
    States that it has an implausable signal.
    Thanks for that info.
  8. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #38
    May 2013
    croydon
    Just had the same thing you have saved me loads of time many thanks
  9. Re: 2002 1.4 TDi Polo charging system fault,lights on dash & power steering failure !
    #39
    Jun 2021
    West Midlands, Uk
    Quote Originally Posted by rta View Post
    I appreciate it's been a few years - trying to resolve a similar issue myself - did you get it fixed and if so, can you remember what it was?
  1. 1.2 Polo 2002 - power steering fault
    By vw1992 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-10-2009, 08:51 AM
  2. Polo 2002, 1.2 ABS system
    By weekendsession in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 01:58 PM
  3. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  4. 2002 Polo synchromesh failure
    By Bossy in forum Polo - Derby - Lupo - Fox
    Last Post: 14-11-2007, 06:46 PM
  5. Polo dash lights
    By FingerPrint in forum Polo - Derby - Lupo - Fox
    Last Post: 12-11-2007, 07:46 PM
