Thread: Vag Results , Anyone want to quote me and repair?
  1. Vag Results , Anyone want to quote me and repair?
    Glasgow
    I ran a vag check on my car ,there is quite a list . I am looking for someone who knows golf's and can fix it. If anyone is willing to fix it, I need a price as I just want to go to the one person and not 10 different people. The car was in a wee crash but is fully fixed now and like new. Its just mainly wee sensors and anoying things. Here are my results below.
    P.s. Can supply the vag test equipment also
    VAG-COM Version: Release 303.1
    Chassis Type: 1J - A4 VW Golf IV
    Scan: 01,02,03,08,15,17,19,22,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 032 FK
    Component: 2.0l 2V AGW 4369
    Coding: 00001
    Shop #: WSC 00000
    WVWZZZ1JZ3W407124 VWZ6Z0B0382580
    10 Faults Found:
    17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
    P1326 - 35-10 - - - Intermittent
    17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
    P1325 - 35-10 - - - Intermittent
    17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
    P1327 - 35-10 - - - Intermittent
    17928 - Intake Manifold Valve 2 (N261): Open Circuit
    P1520 - 35-10 - - - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
    P1628 - 35-10 - - - Intermittent
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 35-10 - - - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
    P1117 - 35-10 - - - Intermittent
    17843 - Secondary Air Pump Relay (J299): Short to Ground
    P1435 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019458
    Shop #: WSC 01271
    1 Faults Found:
    00287 - ABS Wheel Speed Sensor: Rear Right (G44)
    003 - Mechanical Failure - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 3B1 907 044 C
    Component: CLIMATRONIC C 2.0.0
    Coding: 11000
    Shop #: WSC 01271
    6 Faults Found:
    00792 - A/C Pressure Switch (F129)
    35-00 - -
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-00 - Open or Short to B+
    00281 - Vehicle Speed Sensor (G68)
    37-10 - Faulty - Intermittent
    00797 - Sunlight Photo Sensor (G107)
    01273 - Fresh Air Blower (V2)
    01274 - Air Flow Flap Positioning Motor (V71)
    37-00 - Faulty
    Address 15 -------------------------------------------------------
    Controller: 1C0 909 605 A
    Component: 27 AIRBAG VW51 01 0006
    Coding: 12855
    Shop #: WSC 01271
    10 Faults Found:
    00595 - Crash Data Stored
    35-00 - -
    01214 - Crash Data for Belt Tensioner Stored
    35-00 - -
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    00588 - Airbag Igniter: Driver Side (N95)
    32-10 - Resistance too High - Intermittent
    00589 - Airbag Igniter 1: Passenger Side (N131)
    00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter: Passenger Side (N154)
    00532 - Supply Voltage B+
    07-10 - Signal to Low - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    01218 - Side Airbag Igniter: Passenger Side (N200)
    Address 17 -------------------------------------------------------
    Controller: 1J0 920 926 A
    Component: KOMBI+WEGFAHRS. RB8 V27
    Coding: 07422
    Shop #: WSC 00792
    2 Faults Found:
    01314 - Engine Control Module
    01330 - Central Control Module for Central Convenience (J393)
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01271
    3 Faults Found:
    00778 - Steering Angle Sensor (G85)
    Address 46 -------------------------------------------------------
    Controller: 1C0 959 799 B
    Component: 1Y Komfortger&#225;t HLO 0003
    Coding: 00064
    Shop #: WSC 01271
    3 Faults Found:
    01131 - Control Circuit for Turn Signals
    25-10 - Unknown Switch Condition - Intermittent
    37-00 - Faulty
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    27-10 - Implausible Signal - Intermittent
    Address 56 -------------------------------------------------------
    Controller: 1J0 035 186 E
    Component: Radio BNO 0006
    Coding: 01403
    Shop #: WSC 01271
    3 Faults Found:
    00856 - Radio Antenna
    36-10 - Open Circuit - Intermittent
    00852 - Loudspeaker(s): Front
    36-00 - Open Circuit
    00853 - Loudspeaker(s): Rear
    End -------------------------------------------------------
  2. Re: Vag Results , Anyone want to quote me and repair?
    Nottingham
    That's too far away for me to help or quote you, what I can say is you want to first off get it scanned with a full version and erase all the fault codes. Then drive it for a week, then re-scan it. Then post the new scan back here - because I'm hoping a lot of that is old, either that or it will be more than one visit to the garage I can tell you - and a lot of money.
  3. Re: Vag Results , Anyone want to quote me and repair?
    nottinghamshire
    damn, that is a list and a half
    would it be quicker to tell us what does work!! lol
  4. Re: Vag Results , Anyone want to quote me and repair?
    A, A
    I agree with Greg123, get it cleared of codes first then run it to see if they return.
    Might not be any at all.
    Does the car act as it shouldnt and is the EML on ?
    Just another B7 Estate
  1. Cambelt change - quote
    By tpl288 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2008, 10:51 AM
  2. What quote should i expect for Axel Bush replacement on Bora?
    By Fizzbitt in forum Bora - 1998 - 2005
    Last Post: 23-11-2007, 11:08 AM
  3. Cheapest Quote for retro fitting Cruise Control
    By Loofer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-09-2007, 03:31 PM
  4. My Vag-Com Results - Help Please
    By craigbeal in forum Audi A3 - Archive Topics
    Last Post: 30-07-2007, 05:14 PM
  5. Vw Tamworth Quote
    By Ben in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-02-2007, 04:18 PM
