Thread: Having a nightmare with battery drain!
Results 1 to 10 of 14
  1. Having a nightmare with battery drain!
    May 2007
    Hornchurch, Essex
    It's just one thing after another lately! Today was the 3rd time i've called out the rac to get my battery going. To cut a long story short, they said the battery is good. One rac bloke told me the radio was draining the battery when off. I simply took the fuse out and all was well. I got brave and put it back in ages ago and all seemed well. Today it's dead again so i told this rac man about the radio. With the radio fuse in it's draining at 2.5 amps, took radio fuse out and it went down to 1.3 so something else is also draining it as i'm told it should be around 0.3. I did take the courtesy light unit out of the boot last night as the bulb had gone. Not knowing much about electrics or mechanics i asked if that could have anything to do with it and he said no. I also asked if the doors had to be locked for the ecu to actualy rest and he said no, i'm sure i've read it stays live until it's locked????
    So i've more than likely got a dodgy head unit and now something else is draining the battery. I cant afford to take it to the ********, any suggestions would be a great help. I recently replaced the fuse for the cigarette lighter which had been blown for about a year.
    I'm at my witts end with this car, i simply cant afford to keep fixing things, i'm so near to letting it go now and i really dont want to.
    AUDI A4 1.8T QUATTRO SPORTS : 2001 B6
  2. Re: Having a nightmare with battery drain!
    133 Post(s)
    1989 Post(s)
    Is it fuse 37 you are taking out and what radio is it? The drain should be less than 0.1 amps.
  3. Re: Having a nightmare with battery drain!
    May 2007
    Hornchurch, Essex
    hi crasher, sorry mate, more problems! bose symphony system. fuse 39 (radio).
  4. Re: Having a nightmare with battery drain!
    133 Post(s)
    1989 Post(s)
    Can you double check it is fuse 39 and PM me your reg number.
  5. Re: Having a nightmare with battery drain!
    133 Post(s)
    1989 Post(s)
    I was looking at type 8D 2001, not type 8E 2001, dohh! Disconnect the amplifier.
  6. Re: Having a nightmare with battery drain!
    May 2007
    Hornchurch, Essex
    lol, cheers. I take it fuse 37 (power module) is the amp then. so both fuses need to be out to fully disengage the sound system?
    I'll try that then get my mates metre on it to see if makes a difference.
    If it does turn out to be the amp draining the extra power, what do you think my chances are of getting it fixed? I know it's not possible to diagnose over the forum but is it POSSIBLE it's something simple or am i more than likely looking at a whole new system? i.e head unit and amp
  7. Re: Having a nightmare with battery drain!
    133 Post(s)
    1989 Post(s)
    No, fuse 37 is for an 8D, yours (an 8E) is fuse 39 for amp and head unit.
  8. Re: Having a nightmare with battery drain!
    May 2007
    Hornchurch, Essex
    oh right, so how do i disconnect the amp then like you said? surely if fuse 39 is out then it is disconnected?
  9. Re: Having a nightmare with battery drain!
    133 Post(s)
    1989 Post(s)
    The amp is in the boot. The idea is to decide whether the amp is taking the draw or the head unit.
  10. Re: Having a nightmare with battery drain!
    May 2007
    Hornchurch, Essex
    Ok, that takes care of the sound system draw but i still have a further 1.5 amps draining from somewhere else. I got an electrics guy coming round next thursday so see what happens.
  1. Getting at the drain under the Passat battery
    By swampman in forum Volkswagen
    Last Post: 22-12-2009, 12:30 PM
  2. battery drain
    By jasey1007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 08:29 PM
  3. Another battery drain issue
    By g7kse in forum Golf MK5 - 2004 - 2009
    Last Post: 09-01-2008, 03:38 PM
  4. passat tdi battery drain
    By andycampers in forum Passat - Archive Topics
    Last Post: 18-11-2007, 04:37 PM
  5. Battery drain
    By nickasaki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2006, 01:51 PM
