Thread: corrado g60 cutting out
  1. corrado g60 cutting out
    Jan 2008
    hi i have a corrado g60 just had it tuned and when i start it it keeps popping and bangiging when cold..as soon as the oil temp gets to about 58 its fine..looks like a cold start problem but the place that tuned it dont no whats wrong...can anyone help..its doing my head in...thanks
  2. Re: corrado g60 cutting out
    May 2007
    surrey / yorkshire
    Lambda sensor ?
    or your CO pot is well out. Who tuned it?
    Audi A4 B5 1.8T
  3. Re: corrado g60 cutting out
    2007 Post(s)
    As I told you this morning that I think it is the ECU. I tuned it by the way, the basic settings are dead on, the lambda sensor doesn’t operate from start up and the car is quite heavily modified with some "changes" I don't really like such as atmospheric dumping crank case ventilation and boost return. It only ever did it to me once and I am sure it is the re-mapped ECU’s cold running table.
  4. Re: corrado g60 cutting out
    May 2007
    surrey / yorkshire
    if all the setting are right then it does sound like an ecu tuning issue.
    i don't like the sound of the atmopheric boost return either.
    i had issue with a chip in my g60 ( wish i'd kept it now ) and found it was over fueling from cold
    Audi A4 B5 1.8T
  5. Re: corrado g60 cutting out
    Jan 2008
    Quote Originally Posted by tut_gareth View Post
    Lambda sensor ?
    c and r enterprses...steves well up on his knoledge though
  6. Re: corrado g60 cutting out
    May 2007
    surrey / yorkshire
    Those guys have been around for a fair while and from what i have heard they know what they are doing.
    what chip is your ecu running?
    Audi A4 B5 1.8T
  7. Re: corrado g60 cutting out
    2007 Post(s)
    That is me by the way!
  8. Re: corrado g60 cutting out
    May 2007
    surrey / yorkshire
    (thought so)
    I agree with you about the ECU maybe being at fault.
    Audi A4 B5 1.8T
  1. Corrado VR6
    By chrisp in forum Scirocco - Corrado
    Last Post: 10-06-2009, 08:56 AM
  2. Corrado wipers
    By Robin K-S in forum Scirocco - Corrado
    Last Post: 30-10-2007, 08:39 AM
  3. Airbag Corrado?
    By Drivrfound in forum Scirocco - Corrado
    Last Post: 01-08-2007, 03:18 PM
  4. Corrado door
    By eugmul in forum Scirocco - Corrado
    Last Post: 24-05-2007, 11:15 PM
