Thread: Passat Warning triangle in boot recess
  1. Passat Warning triangle in boot recess
    Dec 2006
    I have just bought a warning triangle for my passat from ebay. The auction had a picture of a passat b5 with the triangle in the boot recess (attached) I tried to fit it earlier and there is no way it seems to fit. Its in its folded position, but when placed in position in the bootlid, there is no way of getting the clamp over to screw it back in.
    The part is genuuine VAG, although it it stamped with the audi logo and part number 4B5 860 251 B. Does anyone know if this is the correct part or can you check it against yours? I may pop down to volkswagen and ask them to clarify it for me.
  2. Re: Passat Warning triangle in boot recess
    Part no is the same as mine (B5.5), I think you will need a new bracket, I had to buy one for mine ( I think a B5.5 bracket will fit your boot recess) only £6 from the local dealers, very cheap I thought.
  3. Re: Passat Warning triangle in boot recess
    Dec 2006
    No luck at VW, I think the man at the parts desk thought I was a little sad! I explained the situation (that I appear to have a triangle from a b5.5 and could I buy a bracket for a b5.5 to fit to my b5) but he wasn't overly helpful and doubtful it would work!!
    From the picture above and the triangle I have, the problem seems to be the feet that keep it up. On mine, the feet are located underneath the triangle and the one I need (pictured) the feet appear to be tucked behind the triangle, allowing it to fit in the recess. With the feet being at the bottom, the unit has too much height to fit in the boot!
    Atleast, this is how I make sense of it....!?
  4. Re: Passat Warning triangle in boot recess
    Dec 2006
    I just googled the part number & found this - may be useful in getting the right bit..
    http://www.istargazer.ca/triangle.html
    .. Hughie
    Blue '06 2.0 TDi 140 from March 2012
    Blue '03 1.9 TDi 130
    Poole, Dorset
  5. Passat Warning triangle
    Dec 2006
    ... I have just purchased a new warning triangle & bracket from Breeze for our 2003
    Triangle 4B5860 251E £21 ish
    Bracket 3B5-860-285B-B41 £4 ish
    I had a temporary non standard triangle so this looks much better
    .. Hughie
    Poole, Dorset
  6. Re: Passat Warning triangle in boot recess
    Sep 2008
    Hi Guys,
    I need a triangle for my B5.5 too but I'm confused I have three part numbers differing only by the letter on the end and I was wondering does anyone know if there's any difference between them or if any of them is model specific i.e.for B5 or B5.5? The numbers are 4B5 860 251B/C/E,
    any ideas? Could any B5.5 owners check their original VW boot mounted safety triangles?
    Thanks Guys!
  7. Re: Passat Warning triangle in boot recess
    Dec 2006
    mouche - i put the part numbers for b5.4 in the post above....
    .. Hughie
    Poole, Dorset
  1. Boot/Tailgate warning light
    By neilglos in forum Polo - Derby - Lupo - Fox
    Last Post: 23-03-2009, 10:56 PM
  2. Replies: 0
    Last Post: 13-11-2007, 05:31 AM
  3. VW Passat Warning Triangle
    By ecosse_driver in forum Passat - Archive Topics
    Last Post: 21-08-2007, 07:02 AM
  4. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
