Thread: A3 Brake warning light
Results 1 to 8 of 8
  1. A3 Brake warning light
    I own an A3 1.9 tdi Qauttro sport on a 53 plate.
    I changed the front brake pads, however whenever I switch the car on the warning light comes on and stays on.
    I have checked the rear pads and they are still over half life left.
    Someone mentioned to me that the sensor wires may be broken hence creating a circuit to make the system believe they still need to be replaced.
    My question:
    Is there a way to clear this light without replacing the pads again?
    Sam
  2. Re: A3 Brake warning light
    Jul 2007
    Cheshire, or my A6
    I bet they were not genuine pads with the ABS sensors in? You could probably try turning this off with VAGCOM but it is most likely it will re-appear.
    Paul
  3. Re: A3 Brake warning light
    Hi Paul,
    You are right they weren't.
    What is VAGCOM?
    Sorry I am new to this!
    When we replaced them they were exactly the same in shape / size / sensor connector!
    What would you receommend?
    Sam
  4. Re: A3 Brake warning light
    A, A
    Do the new pads have sensors on them ?
    Check to see if the sensor is broken.
    IIRC the dash warning lights, ie Brake warning lamp can be turned off via a VAG COM.
    A VAG COM is diagnostic software for a PC that uses a seriel cable to connect to the car.
    Just another B7 Estate
  5. Re: A3 Brake warning light
    When you say sensor...
    On the passenger side there were wires which we connected to a block connector.
    Is it worth disconnecting the connector and fooling the system into thinking all is ok?
    Also where can I buy VAG COM from and roughly how much should I pay?
    Is it easy to use?
    Sam
  6. Re: A3 Brake warning light
    A, A
    Disconnetting the sensor will make the light come on.
    What i did was cut the sensor off the old pads, joined the wires and taped it up and reconnected it.
    An Offical VAG COM is about £150 imported from the USA, but you can buy dummy cabels off ebay, as I have done for about £15, with shareware software.
    The official manufactuers website will give you more info:
    http://www.ross-tech.com/
    The forum search button will bring loads of info up on VAG COM.
  7. Re: A3 Brake warning light
    I'll give that a try.
    Thanks for your help and advice!
    Sam
  8. Re: A3 Brake warning light
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by mluton View Post
    Too true...
  1. Brake Warning Light
    By Seat Driver in forum Alhambra
    Last Post: 24-06-2011, 05:06 PM
  2. Red Brake Warning light
    By fayraz in forum Archive posts
    Last Post: 26-11-2007, 01:09 PM
  3. Brake Pad Warning Light
    By darkskies in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-11-2007, 11:26 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  5. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
