Thread: New battery causing alarm to go off
  1. New battery causing alarm to go off
    Jan 2008
    Hi there
    Just wondering if anyone can help?
    I had a new battery put into my polo today which caused the alarm to keep going off. The car parts shop that fitted the new battery for me couldnt disable it. Apparently its a Logic alarm, which is standard.
    Unfortunately i had to drive home with the alarm and the hazard lights going cos they still couldnt fix the problem by the time they closed for the evening! I had to disconnect the battery when i got home to stop it going off.
    Any ideas would be really appreciated...
  2. Re: New battery causing alarm to go off
    2019 Post(s)
    A Logic alarm isn't standard but may be a dealer fit option. Do you have a fob for the alarm or override key? What year is the car?
  3. Re: New battery causing alarm to go off
    Jan 2008
    Its a 96 P reg and i only have a bog standard key. Not even central locking!
  4. Re: New battery causing alarm to go off
    2019 Post(s)
    You are going to need the alarm removing, are you capable of doing this? I initially I thought it would need cut circuits re-joining but if it runs when triggered it can't have any ignition cuts.
  5. Re: New battery causing alarm to go off
    Jan 2008
    No i have little knowledge of car mechanics or electrics.
    Would i be best calling a moble alarm specialist if there is such a thing?
  6. Re: New battery causing alarm to go off
    2019 Post(s)
    You need an auto electrician of some type to come out and remove the alarm. Don't let them sell you a new one either unless you want one. Your car has a built in passive transponder immobiliser from the factory (a chip in the key is read by a box under the dash which sends a code to the ECU) which is very difficult to get past and is perfectly adequate for your requirements.
  1. MkII Golf ECU/purge valve issue - causing battery drain
    By BillyNoMates in forum Archive posts
    Last Post: 17-01-2008, 03:03 PM
  2. Seat causing backache?
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-09-2007, 06:22 PM
  3. alarm battery/horn
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 04-04-2007, 09:57 PM
  4. New battery causing my problems
    By Jfella in forum Audi A3 - Archive Topics
    Last Post: 31-12-2006, 01:57 PM
  5. Problem with 1.9tdi (n-reg) alarm/immob after battery change
    By Trevaaaaaaa in forum Passat - Archive Topics
    Last Post: 06-12-2005, 06:28 PM
