Thread: interior leak electronic fix
Hybrid View
  1. Lightbulb interior leak electronic fix
    Aug 2007
    kent
    Hi Guys just thought this would be good use to you.
    i suffered from the dreaded blocked drain holes and flooded passanger foot wells. after i fixed the leak i noticed a few of my electrics started playing up. these include my alarm, central locking, windows and interior lights.
    i searched the internet to find this guide to fix all the electronic faults. these are all caused by the comfort control module (CCM)
    http://www.headfuzz.co.uk/?q=vw_ccm
    it definatly helped me out. im sure it will help some of you guys.
    for anyone who hasnt seen it heres the drain hole fix
    http://www.weirdlittlebiscuit.com/passat/leak/index.htm
    vw passat estate 1.8t 1999
  2. Re: interior leak electronic fix
    Las Vegas! eerrrr OK Hawkwell Essex
    I have a 99 Passat TDI
    with the interior lights flashing every time you lock it.
    Checked the CCM in the floor (dry as a bone) all the contacts and connections are fine.
    Its still doing it sometimes with out the CCM clicking.
    Any ideas?
  3. Re: interior leak electronic fix
    May 2008
    nottingham
    just had this problem this morning alarm going off and not locking on key fob, passenger side wet through just took carpet up and stuck a hair dryer in the for about an hour, i made sure all the wires were dry as the ccm was all dry in side so the short was due to the wire/cables leading into the ccm box, got to think of away of water proofing the cables leading to the ccm
    hope this helps
    cheers neil
  1. A6 Electronic Parking Brake
    By GLOVERGLOBAL in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2012, 11:19 AM
  2. Electronic Stablisation
    By fizzwitch in forum A8 - S8 - V8
    Last Post: 19-11-2007, 11:17 PM
  3. Electronic Click
    By Spiceman in forum Passat - Archive Topics
    Last Post: 23-08-2007, 09:53 PM
  4. electronic speedo is not working
    By Dataman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 08:21 PM
  5. Golf MK2 Electronic Help
    By don_chico in forum Golf MK2 - 1984 - 1992
    Last Post: 23-01-2007, 10:03 PM
