Thread: Anybody in dorset can fit my sub/amp wiring kit !!
  1. Anybody in dorset can fit my sub/amp wiring kit !!
    Hi, First i apologise if im not allowed to post this type of message, but is there any kind person that can fit my sub/ wiring kit to my Audi a4 1995 ? basically i have a vibe sub/amp all in one in the boot and just want to no if anybody can fit the wiring kit for me and for a little cheaper than the local hi-fi shop, would do myself but havnt got the time as yet,
    So all i need doing is the live from sub box to engine bay/battery
    remote wire from ub box to stereo
    rca leads from sub to stereo
    and earth to chasis somewhere
    even if it was just for somebody to feed the Live cable from battery to inside the car i can perhaps do the rest myself...
    Any help Please and im in verwood/dorset near ringwood, but could travel locally if needed,
    Many thanks and sorry for this strange request, hope to hear soon and Please p/m me and i will get back to you very soon.
    Regards from brian
  2. Re: Anybody in dorset can fit my sub/amp wiring kit !!
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    I'm passing Ringwood on Saturday 2nd Feb, probably at about 5pm/6pm (not sure yet as I have a club meet at Portsmouth). I could try and lend a hand. I have prior experience of fitting audio in my fabia - One point I had 2 JL 12" subs, 3 amps, door comps, etc. Now all gone though, but I'm sure I can try to lend a hand.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  3. Re: Anybody in dorset can fit my sub/amp wiring kit !!
    Hi Jason and that would be great, bet i get it done by then !! lol, and thats very good of yoou if i havnt done by the 2nd february, keep in touch and i will do the same and let you no how im getting on, again thankyou jason.
    From brian
  4. Re: Anybody in dorset can fit my sub/amp wiring kit !!
    May 2006
    Just drop me a PM nearer the time as I'm not likely to clock into this thread again. It might end up me showing up and saying "you need a X, Y and Z" and then going again.
    Need to ensure you have things like head unit keys in advance. ALso ensure you have the correct ring terminal fitting on the power wire to go over the battery positive terminal. Also you need an inline fuse - hopefully a good one is in the kit. Earth wire? Well should be a good bit on the edge of the boot. Rear seatbelt buckle mounts usually work well. RCA should be easy to plumb in. Also, having torx set to remove trim too. I think the glovebox will have to come out to access a grommet into the engine bay.
  5. Re: Anybody in dorset can fit my sub/amp wiring kit !!
    Kent
    The easiest way to get wire into the car is through where the ECU is (drivers side of the engine bay bottom of windscreen remove cover and clip that holds ECU down and move ECU out of the way you will now see a big hole leading down to the footwell remove the bottom part of the Dash (3 or 4 Bolts) and you should see the hole that comes through the Engine bay.
    Good Luck
  6. Re: Anybody in dorset can fit my sub/amp wiring kit !!
    May 2006
    Good to know as I was going to wire it down the passenger side. Sounds like the driver's side would be better to me.
  1. Audi independent in somerset dorset area
    By rhencullen1989 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 04-01-2014, 12:04 AM
  2. Tow Bar Wiring
    By davej in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 04-09-2008, 04:15 PM
  3. wiring an amp in a mk4 TDI
    By bigwint in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2007, 03:36 PM
  4. Wiring?
    By bromine in forum Passat - Archive Topics
    Last Post: 10-02-2007, 07:33 PM
  5. wiring up an amp in a a3
    By jkruse123 in forum Audi A3 - Archive Topics
    Last Post: 08-12-2006, 03:46 PM
