Thread: LT35 won't start!
Hybrid View
  1. LT35 won't start!
    Durham
    Hi - just new to the forum and need to pick your brains!( I don't have any of my own!)
    I have a diesel LT35 1995- haven't used it since before christmas due to leaking sump- tried to start it today and nothing happened
    Battery is charged- lights, radio, fan etc all work fine
    On turning the ignition key there are no warning lights lit on the dashboard for a few seconds- then a weird crackiling noise from under the dash somewhere- and the battery/oil light heater plug light etc eventually come on- but when you go to start all go out and nothing at all happens- not even a click-
    it was all working fine 3/4 weeks ago- any ideas would be appreciated
    thanks in advance
    regards
    Mike
  2. Re: LT35 won't start!
    Gloucesterhire
    Loose connection on one of the busbar feeds on fusebox or faulty ignition switch feed or switchline at ignition switch maybe?
    Jeff
  3. Re: LT35 won't start!
    Durham
    Hi- thanks- tried all of the connections relays fuses etc- finally managed to suss it- the brand new battery was duff- when fully charged it was only kicking out 11 volts- so afetr a heated argument with the spares shop who said"it could never happen"- i have a replacement battery and everything is fine
    Thanks for taking the time to resopond
    regards
    Mike
  4. Re: LT35 won't start!
    Gloucesterhire
    Np,Glad you got it sorted.
    T5 LWB 2007 102 Transporter Imapped to 135ps,running 9j Mugello alloys & low profiles.
  1. LT35 Coolant sensor
    By Bugzee in forum The Commercial Range
    Last Post: 30-03-2009, 11:51 PM
  2. Vw Lt35 02 Lwb
    By lowmic in forum The Commercial Range
    Last Post: 10-11-2008, 09:22 PM
  3. Car Won't Start
    By TIBO in forum TT - 8N Forum - 1998 - 2006
    Last Post: 22-11-2007, 01:46 PM
  4. LT35 2.5 5cyl pump timing
    By Darren Nesbitt in forum The Commercial Range
    Last Post: 01-11-2007, 02:43 PM
  5. Just saying Hi before I start
    By DubDick in forum New Member Introductions
    Last Post: 03-09-2007, 06:39 PM
