Thread: Power problem with Sony stereo- gamma replacement
  1. Power problem with Sony stereo- gamma replacement
    Mar 2007
    Hi- I've had a Sony 6650 DAB radio fitted by an auto electrician to replace my Gamma stereo. All works well, but if I leave the car for 20 mins or so the stereo loses any stations/clock settings etc I've stored. I'm assuming the continious power supply is in some way switched off when the car is left alone? It's fine for 5 minutes, just has a problem after longer periods...
    Did the Gamma not have a continious power lead input? He sounds baffled so I wanted to check before i return to him.
  2. Re: Power problem with Sony stereo- gamma replacement
    Dec 2006
    Wiltshire
    It sounds like he's not connected it correctly. Does it switch on and off with the ignition properly ?
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: Power problem with Sony stereo- gamma replacement
    You may need to swap the permanent live and switched live over.
    Look at the wiring on the back, there should be a yellow wire (permanent live) and a red wire (switched live - sometimes red and yellow). There should hopefully be connectors on each of these wires, if you swap them round then try tuning the stereo again it should hopefully store your stations correctly.
    http://www.the12volt.com/request/request2.asp
  1. lights on gamma stereo
    By paresh1uk in forum Chat - Anything with wheels
    Last Post: 06-11-2007, 10:38 AM
  2. Gamma Stereo Outputs
    By Hayesmachine in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2007, 10:39 PM
  3. Gamma Stereo - Chk Magazine Error
    By Baron_Samedi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2007, 07:32 PM
  4. RDS on gamma stereo
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 04:44 PM
  5. Gamma Stereo in 97 Passat not responding...
    By Biffins Bridge in forum Passat - Archive Topics
    Last Post: 18-05-2007, 05:22 PM
