Thread: Setting Timing Belt Tensioner - 1.9 TDI AWX
Results 1 to 9 of 9
  1. Setting Timing Belt Tensioner - 1.9 TDI AWX
    Solihull
    I'm in the process of replacing the timing belt on my 2003 (53) 1.9 TDI.
    Apart from the motor factors supplying all the wrong parts, it seems that the timing belt tensioner is nothing like the Haynes manual, so I am at a loss as to know the correct way of setting it....that is assuming that when I get the correct part tomorrow, it will be the same as the one I am taking off.
    The kit that they supplied looks as though it is for an earlier model, with the hydraulic tensioner.
    I will try to attach a photo of the old tensioner. It has a pointer on it, which I am assuming will have something to do with setting the tension.
    Any help greatly appreciated
  2. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Northern Ireland
    be carefull what engines are being show in the diagrams in the hayes manual. the pd engines have different tensioners than the older distribution pump engines. However depending on who makes the kit the design of the tensioner may vary. what make of kit did ya buy ?
    2001 Golf TDI S (ALH) Gone but never forgotten
  3. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Sep 2007
    yorkshire
    That is the newer tensioner in the pics.
    Yes the haynes manual has the one with the hydroulic piston type thingy. (old type) It's the same as the haynes book says but you tension the tensioner clockwise untill the pointer points in the recess.
    2003 AUDI AVANT SPORT TDI
  4. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    133 Post(s)
    1988 Post(s)
    Just be thankful you haven’t got the hydraulic tensioner, setting them up to a 4-mm gap drives be potty! I am going to experiment one day, converting a hydraulic tensioner model to the friction tensioner. You do have the proper cam and crank locking tools, don't you?
  5. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Sep 2007
    yorkshire
    I've done it crasher, The car we spoke about has had a 2001 engine fitted, All I did was change the rear cam cover and drill another hole/tap for the guide roller. It was a bit wonky (my drilling) and the belt runs a little toward the engine side of the cam/sprocket. I'm sure you've got better tools to do the job than I have.
  6. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    133 Post(s)
    1988 Post(s)
    Humm, a bit of a pain in a Golf 4 engine bay.
  7. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Sep 2007
    yorkshire
    Well yes. I meant guide roller btw not tensioner. I'm sure you knew that.
  8. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Solihull
    Thanks for the replies.
    I bought the Laser crankshaft tool and used a 6mm rod for the camshaft.
    The timing belt kit was by Gates - pic of wrong tensioner attached.
    It also had the wrong idler roller.
    The motor factors also supplied me with a tensioner for the air-con belt instead of the one for the auxillary belt, which I ordered.
    I'm hoping they'll have the right parts in stock tomorrow.
  9. Re: Setting Timing Belt Tensioner - 1.9 TDI AWX
    Sep 2007
    yorkshire
    When you tighten the tensioner make sure you counter hold the tensioner while you tighten/torque the nut with your other hand. The pointer moves otherwise. And do it with a cold engine.
  1. Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-06-2008, 01:15 PM
  2. Belt tensioner
    By simonvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-10-2007, 07:58 PM
  3. Timing belt stripped,tensioner broke, Cam question, Please Help
    By tchrgrl in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 03:09 AM
  4. Timing belt tensioner problem
    By gbrownlee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:43 PM
  5. Timing chain tensioner
    By NIgolf in forum Passat - Archive Topics
    Last Post: 20-03-2007, 07:10 AM
