Thread: abs exciter rings
  1. abs exciter rings
    Hi think I've traced my ABS lighton problem , it looks like the exciter rings on the hubs are broken , can anybody tell me if they are seperate parts or intergral to the cv hub ?, before i start stripping them down , also are the dealer parts only ?
    Thanks Eddie
  2. Smile Re: abs exciter rings
    Aug 2007
    Hi Most if not all posts on here suggest they are integral, with the following recommended as a purchase point!
    Quote Originally Posted by andy e View Post
    unfortunately vw are right on this one it is part of the joint, look on fleabay at item no 260111329085, i bought one of these so far ok
    Cheers and HTH
  3. Re: abs exciter rings
    Jul 2006
    scunthorpe
    Quote Originally Posted by carbon8ed View Post
    Cheers and HTH
    you need to change the cv joint, whatever you do DO NOT PUT ANY WEIGHT ON THE HUB WITH THE CV JOINT OUT OF THE HUB IE DO NOT JACK THE HUB UP TO ALIGN THE BALL JOINT AS THIS WILL DESTROY THE BEARINGS IN THE HUB
  1. Fitting Halo rings into my headlight mk4 golf
    By johnyb in forum Golf MK4 - 1999 - 2004
    Last Post: 16-10-2007, 03:57 PM
  2. 2.0 gti 115bhp- piston rings?
    By chloé vwg in forum Golf MK4 - 1999 - 2004
    Last Post: 30-09-2007, 09:14 PM
  3. The Four Rings
    By stuart in forum History - Audi
    Last Post: 08-05-2004, 09:14 PM
