Thread: Mark IV TDI Headlight Change
  1. Mark IV TDI Headlight Change
    Oct 2006
    I've got a cracked headlight and it needs replacing.
    Is this a big job and does anyone know the procedure?
    Cheers in advance
  2. Bumper off I'm affraid
    Oct 2006
    To replace the headlamp, you need to remove the front bumper or drop it down one side at least, to get to lower lamp fixings.
    1. disconnect bonnet pull catch
    2. remove front grill
    3. remove T30 Torx screws (4, I think)
    4. remove both lower vent covers & 2 more T30 torx screws
    5. remove 3/4 per side inner wheel arch T25 Torx screws
    Bumper should then come forward enough to remove Lamp fixings...
    Remember alot of the time bulbs need to swapped to new lamps & headlamp leveling motor swapped over.
    If your not sure book into dealer, will cost about an hours labour!!!
    Hope this heps you out Golfer7
  1. Mark 5 GTI stereo
    By funkstar in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-03-2007, 08:25 PM
  2. Golf Mk4 headlight bulb change
    By Tomstj in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2006, 06:46 PM
  3. Passat Headlight Bulb change
    By sp900 in forum Passat - Archive Topics
    Last Post: 10-10-2006, 03:09 PM
  4. A4 Headlight Bulb Change
    By Aadil Patel in forum Audi A4 - Archive Topics
    Last Post: 20-09-2006, 06:52 PM
  5. 16v mark 3 dying
    By scampi in forum Archive posts
    Last Post: 25-06-2006, 07:35 PM
