Thread: 1996 - Golf TDi - Heater Problems
  1. 1996 - Golf TDi - Heater Problems
    Oct 2006
    Hello All,
    New to the group and also to diagnosing my car problems. The heater / blowers in my '96 Golf TDi have stopped working. It was intermmitent for a couple of weeks but now it does not work at all. None of the 4 levels work. I have checked the fuse and it is ok.
    Any ideas are appreciated before I go and pay for somebody to check it out.
    O
    london/ UK
    Needs new brushes...vw doesnt sell carbon brushes only the whole blower $$$$. Try breakers for a used one from a similar age a3/golf. Its quite a dificult job for a novice so i sugest getting a haynes repair manual from your local halfords breanch or go to a dealer . Good luck.
  3. SWITCH???
    Jan 2006
    Belfast, Ireland
    Could be the switch. May as well try this as it is far easier to get to. The blower motor is in the passenger footwell behind the kick plate bit of dash that drops out with 4 screws. If you have a multimeter it could come in handy!
    The fan packed up on my MK II. First it stopped working in postion one then two, and finally altoghter. The guy in my local parts place said there is a resistor that fails in the fan and is quite common. I replaced it with one from a breakers. Not a bad job.
    However like foolmccool says is could be the switch. My girlfriends MK III the fan doesn't always work in postion three. If I move it back and forth between the postions it works for a while.
    Hope you get it sorted
    Boardboy
    Oct 2006
    Thanks for the replies. I was offline yesterday so have only just seen them. On Monday evening the damn thing would not work through wind and rain and much steaming up. Yesterday driving home in sunny weather all working fine!!
    I got hold of my brother, an ex-mechanic, who also told me to check the switch. Just done that and discovered a mass of cable stuffed around the fan controls from a car stereo install I had done a couple of months ago. About 2meters of the stuff curled up. I've moved that well out the way to see if things get any better. My theory it may have been blocking something. Only time will tell.
    thanks again.
  1. Cutting out problems with 1996 Golf 2.0 Cabriolet
    By John Brogan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 05:05 PM
  2. 1996 t5 starting problems
    By vw motorhome owner in forum Archive posts
    Last Post: 27-12-2006, 01:16 PM
  3. Heater problems
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-11-2006, 09:33 PM
  4. T Reg Golf Heater problems
    By johnm in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-11-2006, 11:08 AM
  5. 1996 - Golf TDi - Heater Problems
    By Octavius in forum Archive posts
    Last Post: 01-11-2006, 02:05 PM
