Thread: 6th gear OK at 60mph? Golf 2.0 gt tdi
  1. 6th gear OK at 60mph? Golf 2.0 gt tdi
    Dec 2007
    I'm new to TDI engines but on my daily commute can do a lot at 60mph with stop & start at each end of journey.
    If I put it in 6th the computer suggests better economy but I'm unsure if this is good for engine (less than 2000 revs) I've read that you should keep it around 2000? Do I save 6th for motorways?
    Thanks if you have any thoughts.
  2. Re: 6th gear OK at 60mph? Golf 2.0 gt tdi
    Coventry
    I have the 2.0 tdi engine. I can potter around quite happily in 6th at 30mph / 1000 rpm.
    very economic.
  3. Re: 6th gear OK at 60mph? Golf 2.0 gt tdi
    Woking
    I have read that it's not great for the turbo as it doesn't spool up enough to oil itself properly until around 1750 revs. However, I think your probably OK and as suggested it does give very good economy. Have a look at the FAQ on www.tdiclub.com for loads of advice about these engines - most of which relates to the MK4 Golf TDIs but which must be relevant as the base technology hasn't changed much.
  4. Re: 6th gear OK at 60mph? Golf 2.0 gt tdi
    Dec 2007
    Thanks for the advice
    Will have a look
  5. Re: 6th gear OK at 60mph? Golf 2.0 gt tdi
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    1800rpm is a good cruise speed for TDIs. It's kind of high enough to be kind to the turbo/engine, yet not high enough to be raucous.
    For cruising I would tend to use (estimated revs for speed)
    30mph - 4th gear @ 1500rpm
    40mph - 5th gear @ 1500rpm
    50mph - 5th gear @ 1800rpm
    60mph - 6th gear @ 1900rpm
    70mph - 6th gear @ 2100rpm (ish)
    80mph - well.... I never go above the speed limit, m'lud.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  1. Golf MK4 - Lurchy when pulling away from first gear
    By Darren-GOLF in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2008, 10:59 PM
  2. Limp mode @60mph !
    By Passat2003 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2007, 10:46 PM
  3. Topping Up Gear Oil On Mk4 Golf
    By tonyleach in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 09:08 AM
  4. Golf third gear crunching
    By Rambo in forum Golf MK3 - 1993 - 1999
    Last Post: 25-06-2007, 06:03 PM
  5. Gear Changing Problem On Mk.3 Golf
    By mac500 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-02-2007, 09:02 PM
