Thread: pressure valve soloniod????
Results 1 to 10 of 10
  1. pressure valve soloniod????
    i have an lt35 that wont start. i have plugged the diagnostic machine in and it told me that it pressure valve soloniod 2 is faulty.
    Can anyone tell me where this is ???
    Thanx
  2. Re: pressure valve soloniod????
    134 Post(s)
    2025 Post(s)
    Year and engine code?
  3. Re: pressure valve soloniod????
    it i the first of the 1999 and the engine number is AHD.
  4. Re: pressure valve soloniod????
    134 Post(s)
    2025 Post(s)
    Sorry, forgot to ask for the fault code, P or VAG, doesn’t matter.
  5. Re: pressure valve soloniod????
    the diagnostic machine says "17957 charge pressure control soloniiod valve 2 intermittment malfunction"
    Would this stop it from starting?
  6. Re: pressure valve soloniod????
    134 Post(s)
    2025 Post(s)
    17957P1549 Solenoid valve of boost pressure control -N75 Open circuit/Short to earth.
    This will not be the starting issue.
  7. Re: pressure valve soloniod????
    ok thanx
    we have had a light on the dash flashing but it has hasnt effected the running.
    any ideas??
    we drove it pulled up. went to drive it the next morning and it turned over but would not start
  8. Re: pressure valve soloniod????
    134 Post(s)
    2025 Post(s)
    What diagnostic system are you using? Have you tried spraying in a little easy start?
  9. Re: pressure valve soloniod????
    it is a sykes system and i havn't tried any easy start but i have not had any problems b4
  10. Re: pressure valve soloniod????
    134 Post(s)
    2025 Post(s)
    If it runs with Easy Start then you can assume it is a fuel delivery issue and a common one is the pump timing jumping.
  1. low oil pressure..
    By gibo in forum Audi A3 - Archive Topics
    Last Post: 11-12-2007, 11:43 PM
  2. oil pressure
    By TWVB in forum Golf MK3 - 1993 - 1999
    Last Post: 15-11-2007, 09:24 PM
  3. oil pressure
    By 01394graham in forum Polo - Derby - Lupo - Fox
    Last Post: 12-09-2007, 10:31 PM
  4. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
  5. Pressure drop between turbo & throttle valve
    By Tony_B in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2006, 10:22 PM
