Thread: crackshaft pulley bolt
Results 1 to 8 of 8
  1. crackshaft pulley bolt
    does anyone know how to unscrew the cranksaft pulley bolt in the centre, i think it is a cheese head bolt and i was wondering if it had a reverse thread, as i have done what haynes manual tells me to by selecting 5 gear and having an assistant applying the brakes and then with a breaker bar attempted to undo the bolt but it does not move. any ideas???
    I'm trying to change the cam belt.
  2. Re: crackshaft pulley bolt
    Hi You do not have to loosen IT to change the timing belt
  3. Re: crackshaft pulley bolt
    Would it be possible to run me through how i get the old timing belt off and a new one on with the crankshaft polley still on?
  4. Re: crackshaft pulley bolt
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    on a mk3 u just undo the 4 allen key bolts and the bottom pulley will come off, no need to undo the big crank bolt, however if you do, u can use a large flat screw driver and hold it in the flywheel teeth through the inspection hole it the top of the gearbox.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  5. Re: crackshaft pulley bolt
    hi, i undid the 4 allan bolts and only the outer polley for the v belt that powers the power steering came off, will the ribbed polley come off as well without undoing the large centre bolt? if does it need some force to get it off? thanks
  6. Re: crackshaft pulley bolt
    Dec 2007
    44 Post(s)
    yes it will come off you may have to wiggle it, or tap it with a hammer, carefull not to damage it though.
  7. Re: crackshaft pulley bolt
    131 Post(s)
    1976 Post(s)
    DO NOT remove the 12 point centre bolt, if you do you MUST replace it and tightening it up is not easy without the VW crank locking tool.
  8. Re: crackshaft pulley bolt
    Thanks for all ur help, i managed to get it off eventually after using a puller, it was certainly on fast though.
  1. Air Conditioner Pulley
    By NickW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2015, 03:02 PM
  2. mysterious bolt
    By lostplanet in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2007, 11:36 PM
  3. A4 Hub/Bearing Bolt-On
    By ChrisFurlong in forum Audi A4 - Archive Topics
    Last Post: 30-08-2007, 06:55 PM
  4. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
  5. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
