Hey...i purchased a 2nd hand 3 button passat fob key(which has the correct code on inside of the key) with a blank uncut blade which is ready for cutting......
i was looking for instructions on programming the key and i saw the link below but this is for an A4;
is a passat done the same way or is there different instructions for a passat??from reading the instrutions it seems i might be able to do it myself??!!(possibly)
after programming it,will the new key work with the immobilisier and do everything my orginal key is doing,3 buttons working or is there further work necessary?
thanks for yer help
Key Fob Programming for Audi A4 - https://www.vwaudiforum.co.uk/forum/s...ead.php?t=1301
it says
Programming remote unit
- Switch ignition ON.
- Lock vehicle mechanically at left front door using second key.
- Press "Open" button on first remote unit (key fob) once (to assign memory address to remote unit number one).
Note: The alarm horn will sound briefly each time the "Open" button is pressed to confirm the reception of the signal during this process.
- Wait six seconds after sending last signal, then press "Open" button again.
^ Doors will now unlock (remote unit is now programmed).
- Lock vehicle mechanically again using second key.
- Press "Open" button on second remote unit (key fob) twice at 1 second intervals (to assign memory address to remote unit number two).
- Wait six seconds after sending last signal, then press unlock button again.
^ Doors will now unlock (2nd transmitter is now programmed).
- Repeat procedure for additional remote units (key fobs) to assign memory addresses number 3 and 4 if necessary.
- Switch ignition OFF.
- Check each transmitter for proper function "
