Thread: Driveshafts! is this normal???
Hybrid View
  1. Driveshafts! is this normal???
    Dec 2007
    I am still having trouble locating a rumble from the front of my golf. It has just passed the mot. It sounds like a wheel bearing. the noise disappears when i turn slightly left, but it is hard to pinpoint exactly which side it is coming from. I was looking at the hub nuts and i found that the passenger side one is new, it also has a washer behind it! should it be there?
    I was looking under the gearbox and saw this,
    this is the drivers side lying under the car with feet out the front. What is the yellow bit and is it normal??
    Thanks. sorry for another long post
  2. Re: Driveshafts! is this normal???
    Jan 2006
    Leigh
    Um, not got a clue. I do know though that the front wheel bearings on the MK3 Golf need to be changed using a hydraulic press. Maybe one side has been changed and not re-fitted properly?
    '99 B5 Passat 1.8 T 20v Sport
  1. Smoke more than normal!
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-10-2007, 09:34 AM
  2. Golf mk3 knocking noise - Driveshafts, CVs or engine mounts?
    By p1nke in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2007, 05:13 PM
  3. Is this normal ????
    By southwest in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-08-2007, 11:19 AM
  4. driveshafts
    By mitchcar01 in forum Archive posts
    Last Post: 20-04-2007, 12:12 PM
  5. S3 driveshafts on Golf 4Motion, would it fit?
    By Mokeylock in forum Archive posts
    Last Post: 05-03-2007, 12:13 AM
