Thread: water leak
  1. Unhappy water leak
    hi
    i have a 51 plate passat sport tdi 130,and i do about 600 miles a week in it,lately it has been using/losing water,there are a few signs of water leaking on the drive,but i cant find a leak i have left it runnung on the drive trying to get it hot enough but there is no water leaking(that i can see) i have changed the expansion bottle cap and there is a slight chance its leaking from the bottle because its slightly wet ,i have had it pressure tested and the pressure does drop but again no visible water loss,also had 2 checks to see if head gasket failure,the CO2 machine in the expansion tank reading hydro carbons they are no higher than regular air around us, anymore ideas cos i am proper fed up at the mo
    cheers
  2. Re: water leak
    Sep 2007
    yorkshire
    Water-pump (remove the top cam cover to see) o-rings on the radiator pipes, the little pipe that runs under the tandem pump and into the head can rub thin and leak. others of course but I've come across these myself.
    2003 AUDI AVANT SPORT TDI
  1. A4 water leak
    By niffy53 in forum New Member Introductions
    Last Post: 06-10-2007, 01:58 PM
  2. A4 TDi Water leak
    By niffy53 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2007, 08:41 PM
  3. A4 TDi Water leak
    Last Post: 04-10-2007, 03:26 PM
  4. A4 Water leak
    By niffy53 in forum Chat - Anything with wheels
    Last Post: 03-10-2007, 09:26 PM
  5. Water Leak
    By silentwitness in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 11:05 PM
