Thread: Randomly wont start, not turning engine over.
  1. Randomly wont start, not turning engine over.
    I have a polo 1.4 X reg, petrol. Recently fitted a new battery, as the old one was not holding it's charge. A few days ago the car would not start, nothing happened at all when the key was turned- even though all other electric systems worked ok, ie. lights, radio etc. So I thought it will probably be a flat battery (maybe I left the light on or somthing), so I bump started the car and it started up fine. I get home, swith car off and try to restart.....nothing again. Test battery and that is ok, fully charged. I check the fuses....all are ok, and decide to just try starting it again, and suprise, it starts.
    Now is is just a coincidence that it started after checking the fuses....could it be an ingition swtich problem? Or something else?
    Hope your can help!
  2. Re: Randomly wont start, not turning engine over.
    May 2007
    newcastle
    The same thing happened with my 1.4 w reg polo last Friday, had 2 bump start it to get home, i took the starter motor off and it worked fine,so i put it back on now it works!... you could try the battery and starter connections to see if they are tight. The stator motor is the the hardest place 2 get to so you will need to get the car up a hight.
  3. Re: Randomly wont start, not turning engine over.
    May 2007
    newcastle
    The same thing happened with my 1.4 w reg polo last Friday, had 2 bump start it to get home, i took the starter motor off and bench tested it and it worked fine, so i put it back on now it works!... You could try the battery and starter connections to see if they are tight. The starter motor is the the hardest place 2 get to so you will need to get the car up a hight.
  1. car wont start up plz help
    By danny_768 in forum Audi A4 - Archive Topics
    Last Post: 06-01-2008, 07:54 PM
  2. Engine Cuts out / Wont Start
    By james_101 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2007, 10:16 AM
  3. vento engine wont start
    By norton in forum Vento - 1994 - 1998
    Last Post: 25-07-2007, 10:23 PM
  4. Washed engine, now wont start
    By abc123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-07-2007, 04:27 PM
  5. a6 1.8T wont start
    By loco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-01-2007, 12:21 AM
