Thread: Stuck CD in Audi A3 Concert System
  1. Question Stuck CD in Audi A3 Concert System
    Hi All,
    Does anyone know how to remove a stuck CD in the Audi A3 Concert stereo ?
    thanks in advance.
  2. Re: Stuck CD in Audi A3 Concert System
    High Wycombe, Bucks
    Is it from the autochanger?
  3. Re: Stuck CD in Audi A3 Concert System
    Hi Mike,
    No, it's a single disc system. Hope you can help mate.
  4. Re: Stuck CD in Audi A3 Concert System
    High Wycombe, Bucks
    Mine is an autochanger so I don't know how the single one works. Some CD players have a detachable facia and behind that you may find a small hole that you can poke an opened up paperclip into and push the CD out.
    If that don't work try sliding a thin putty knife into the slot and gently wigling it around. Try both above and below the stuck disc, this can sometimes free the disc.
    If that does not work try wrapping some gaffer tape tightly and thinly around a putty knife with the sticky side out. The taper of the knife should stop the gaffer tape coming off. Put some paper on one side to prevent that side sticking, then carefull stick the knife to the disc and try to pull it out. Don't get the tape stuck in there too.
    You will probably ruin the disc and don't attempt this if you fear the player may be damaged. I accept no responsibility for any of these methods but have been succesful with the thin knife in the past.
    The safest way to remove the disc is take it to a ICE specialist and pay them to get it out.
    Good luck
  5. Re: Stuck CD in Audi A3 Concert System
    I have had a stuck cd before in a single slot mech and found after resetting the unit it has ejected, if yours doesnt have a reset button or reset function in the owners manual i would remove the unit from the dash and (providing you have the anti theft code to reactivate the stereo) unplug the power and leave it for 10 mins. This may reset the functions.
    When you press the eject button do you hear the motors trying to eject the cd or does nothing happen at all?
    Good Luck
  6. Re: Stuck CD in Audi A3 Concert System
    Hi Guys. All is well now, I tried using the thin / butter knife approach and after a few twiddles and cursing the CD ejected. I might upgrade to ipod compatible system, do you guys know of any good ones out there ? Anyway thanks for the previous replies.
  7. Re: Stuck CD in Audi A3 Concert System
    glad you got sorted, i have a pioneer deh-p4900ib single cd with ipod lead connecton fitted in my works van and it works well, the control of the ipod is much quicker than my mates alpine which also needs a seperate interface box for the ipod.
  1. Audi Concert System advice
    By parmaham in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2007, 01:30 PM
  2. Audi Concert System Problem
    Last Post: 31-08-2007, 05:57 PM
  3. Audi Concert System
    By otis_b in forum Audi A4 - Archive Topics
    Last Post: 21-08-2007, 03:56 PM
  4. Concert Sound System Spec
    By Crisis in forum Audi A3 - Archive Topics
    Last Post: 28-05-2007, 05:18 PM
  5. concert system wiring
    By iaina4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2007, 02:40 PM
