Thread: ticking noise when engine idling
Results 1 to 10 of 19
  1. ticking noise when engine idling
    Jul 2007
    my W reg 1.8T Passat estate was due for it's 130000 miles service
    plus I'd noticed a ticking noise when engine idling so took her
    in to VW.
    VW said they suspect "oil pump pressure and blockage of oil ways in
    the engine".
    Also said something about tappets and that there was a VW bulletin
    about this problem with my engine.
    Basically too expensive to fix (14 hours labour plus parts!).
    I think he said the worst case scenario is the engine just stops/blows up and is damaged.
    Does all this sound likely and anybody have any ideas what else it could be ?
    I had the timing belt done in the last 6 months at a different garage with a new "vibration damper".
    Could noise be related to this ?
    R
  2. Re: ticking noise when engine idling
    Sep 2007
    yorkshire
    Quote Originally Posted by roguetone View Post
    WOW, They really know how to pick there words!
    Does sound like a lifter. As far as the (these engines are known to blow up) is concerned, is irrelevant really!
    Did they even check the oil pressure?
    2003 AUDI AVANT SPORT TDI
  3. Re: ticking noise when engine idling
    134 Post(s)
    2021 Post(s)
    To start with have the sump removed and the oil pick up pipe cleaned out but this is still quite a job as the subframe has to be lowered.
  4. Re: ticking noise when engine idling
    Jul 2007
    Thanks for the reply,
    ".. Does sound like a lifter..."
    whats a lifter ?
    you've got me worried now !
    so you don't think it could be the cam belt ? I guess I could take
    it back to the garage that fitted the belt and ask their opinion.
  5. Re: ticking noise when engine idling
    Sep 2007
    yorkshire
    You could try an engine flush followed by a oil and filter change after. but the lifter/s may still need changing!
    Before you attempt the sump removel.
    I would think the oil pressure wants checking first.
  6. Re: ticking noise when engine idling
    134 Post(s)
    2021 Post(s)
    Clogging of the oil pick up on the 1.8T is a terrible problem, even the slightest suggestion of clogging MUST mean the removal of the sump or a total loss of engine and turbo may result. The lifters (hydraulic tappets) usually come back to life if this isn't left too long. If the dealer is concerned that there is a lack of oil pressure, please do not disregard this, I see this time and time again. It is how I bought my 2003 Octavia VRS, the previous owner disregarded the warnings and then could not afford £5K for a new engine and turbo to be fitted. Member a8 tech on here will fully back me up on this, PM him and ask his opinion. Must go now, the wife needs chocolate and coffee so I must obey!
  7. Re: ticking noise when engine idling
    Sep 2007
    yorkshire
    ME TOO.
    Is your sump still on.....
  8. Re: ticking noise when engine idling
    Jul 2007
    well they did an oil and filter change so i hope so
    I'm no mechanic in case you hadn't guessed but I looked this up so I think when you say lifters you mean the hydraulic tappets?
    These are the things that lift the valves right, driven by cam shaft ?
    So what's oil pressure got to do with this (no warning light on dash by the way). And what is actually making the ticking noise, the tappets because they're not properly lubricated ?
  9. Re: ticking noise when engine idling
    Are u sure its the lifters ticking and not the injectors,dirty injectors also tick at idle but the noise goes at about 1500 rpm lifters still tick until at least 2000rpm if i were you i would drain my fuel filter and pour a can of forte injector cleaner into it and go for a blast up the motorway if its still ticking go look at your sump pickup. Ed
  10. Re: ticking noise when engine idling
    134 Post(s)
    2021 Post(s)
    I mentioned lifters being hydraulic tappets in my post above. On older engines (and still some modern engines like the Jaguar V8), the follower (or tappet) clearance was adjusted manually. The clearance is necessary to take into account thermal expansion. Anyway, to reduce maintenance costs and improve refinement, tappets are now commonly pumped up with oil to maintain a zero clearance but without the problems associated with doing that with sold tappets. If the oil pressure drops, the tappet leaks down and a clearance develops and that is where the noise comes from.
  1. Ticking noise from Air Conditioning...
    By robertok in forum Passat - Archive Topics
    Last Post: 24-01-2008, 11:50 PM
  2. Ticking noise while driving?
    By naz121 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-10-2007, 12:16 AM
  3. Excessive engine ticking noise 1.9TDI AFN
    By Jimbob1981 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-09-2007, 08:16 AM
  4. Ticking Noise on Start Up
    By lennymfo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2007, 09:07 AM
