Thread: a4 b5 water leak help
Hybrid View
  1. a4 b5 water leak help
    Apr 2007
    hi i have a 96 a4 i am having a water leak problem a couple of days ago i went to get in to my car only to find a pond in the drivers footwell, damn i thought i have checked the sunroof drains they are not blocked and sunroof is not leaking,
    any clues
    thanks chris
  2. Re: a4 b5 water leak help
    Hi Chris,
    It sounds like you have the same problem as me. That's why I came looking for this site.
    Check this thread regarding previous discussion and the advice I've received.
    https://www.vwaudiforum.co.uk/forum/s...d=1#post115791
    Basically I've been told that there is a drain under the battery that can become blocked and causes water to overflow into the interior.
    I'm going to try to sort mine out tonight.
    I'll report back when I'm done.
    Dan
  3. Re: a4 b5 water leak help
    Apr 2007
    excellent thanks dude thought it might be somewhere there will have fun with that tonight bloody strut brace will have to come off only two bolts but a night mare to fit
    cheers dan
  4. Re: a4 b5 water leak help
    Hi Chris,
    Managed to get mine done.
    I have a bit more info that might also apply to your car. I actually found that there are TWO drains in mine. The one below the battery and another one just below the brake servo which actually looks to be at a lower level than the first one.
    Both were blocked and are now cleared.
  5. Re: a4 b5 water leak help
    Didn't have my radio code so couldn't remove my battery so it was out with the Black & Decker to make a new hole and a very common problem.
  1. Water Leak!!!
    By wheela33 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-12-2007, 02:50 AM
  2. A4 water leak
    By niffy53 in forum New Member Introductions
    Last Post: 06-10-2007, 01:58 PM
  3. A4 TDi Water leak
    By niffy53 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2007, 08:41 PM
  4. A4 TDi Water leak
    Last Post: 04-10-2007, 03:26 PM
  5. A4 Water leak
    By niffy53 in forum Chat - Anything with wheels
    Last Post: 03-10-2007, 09:26 PM
