Thread: A silly question about my air con!
  1. A silly question about my air con!
    Oct 2007
    Hi. Sorry if this is a silly question but I didn't get a manual with my car!
    I was having problems turning on the air con yesterday - the air con symbol would only light up for a second then turn off.
    A few posts on the forum say the air con does not work when it is too cold outside (the frost warning was on the dash yesterday). It is slightly warmer today and the aircon is fine.
    Is this correct? I thought you had to keep using the air con in winter and it was useful for demisting the windows?
    Thanks for any help! Ian
  2. Re: A silly question about my air con!
    Apr 2007
    Hampshire
    The "auto" feature of the climate control will decide if the aircon is needed. Normally it would nor run the compressor in cold weather for the obvious reason its colder than the temp selected. It will run the compressor if the humidity is high and may cause misting on the windows. You shouldnt have any problems with the system if your enjoying mist free motoring!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  3. Re: A silly question about my air con!
    Oct 2007
    Thanks for that. Although I still couldn't manually turn on the air con when the climate control was not in 'Auto' mode.
    I wanted it on as the windows were misting a little.
    I'll see how it goes over the next few days.
    Ian
  4. Re: A silly question about my air con!
    Apr 2007
    Hampshire
    Do you mean your Econ button light wont go out?
  5. Re: A silly question about my air con!
    Oct 2007
    I'm not sure if I have an Econ button!
    Basically the symbol for air con won't go on when the air con button is pressed if it's cold. This is when I need it for demisting! It's the same in Auto or Manual mode.
    Thanks, Ian
  1. ask a silly question!!
    By pd130 in forum Archive posts
    Last Post: 14-12-2007, 12:24 PM
  2. Heres a silly question....
    Last Post: 08-10-2007, 08:51 PM
  3. A silly question about forum meets.
    Last Post: 22-06-2007, 12:20 PM
  4. Really Simple and silly question.....
    By Boraboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-11-2006, 06:11 PM
