Thread: Multi Function Steering Wheel
  1. Multi Function Steering Wheel
    Hi guys. Need some advise. I have read in various posts and other forums that it is possible to change the regular steering wheel to multi function steering wheel on Golfs and Passats.
    I recently acquired an EOS here in Malaysia. It has the 2.0 TFSI with DSG but unfortunately they did not include the MFSW. I'd like to add on the MFSW with the gear shifters. I understand that I will have to get the steering wheel, airbag and control module and then later recode at the dealers workshop.
    The issue now is the dealers are not aware if this is possible and neither do they know the part numbers to order the stuff. I hope someone here can help me out. Having a DSG without paddle shifters is just unnatural..
  2. Re: Multi Function Steering Wheel
    Up North
    You should be able to get away without a new airbag, providing you get the correct EOS wheel and don't go for GTI or R32.
    This forum has lots of information on fitting just the stereo buttons, but you should also find some information about the controller box in the steering wheel. I hope it helps. http://uk-mkivs.net/forums/thread/389858.aspx
    The EOS electrical system is pretty much the same as the Golf, so the info should be applicable.
  3. Re: Multi Function Steering Wheel
    Coventry
    Yes, i agree with you Teflon, so long as the wheel has the paddles then it should be exactly as the Guide i linked to in the How to thread would suggest.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=21274
    I added the link you found teflon
    i also asked when i was down the dealers if they could cost up a retro fit and i was told that they don't do that job.
  4. Re: Multi Function Steering Wheel
    Wow. Thanks guys. Mine came with MFSW without paddles. Hopefully the upgrade would be simpler. Thans again.
  5. Re: Multi Function Steering Wheel
    Up North
    Quote Originally Posted by WOB View Post
    Does that mean you have the radio buttons but not the paddles? If so and you end up with a new steering wheel, do you fancy selling the buttons from the old wheel or even the old wheel itself?
    I've got DSG paddles but no radio buttons on a Golf, so I'd like to upgrade.
  1. Multi-function Steering Wheel retrofit
    By morph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2009, 06:23 PM
  2. Multi function steering wheels?
    By Heathy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-01-2008, 08:23 AM
  3. 02 Golf GT TDI Multi Function Indicator
    By 351 anglia in forum Archive posts
    Last Post: 26-08-2007, 10:08 PM
  4. Multi function steering wheel
    By andcra in forum Chat - Completely Off Topic
    Last Post: 02-01-2007, 11:07 PM
  5. Golf Mk IV Multi Function Display
    By cwinterb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-10-2006, 08:06 AM
