Thread: Where to find VW GOLF MK4 starter relay
  1. Where to find VW GOLF MK4 starter relay
    Dec 2007
    London(Middlesex)
    Spark Plugs not working up when turning the ignition on and sometimes when I drive the spark lug light is flashing on a dashboard. I think it's about time to change the stater relay, but couldn't find it where it is. Not sure if it's under stirring wheel behind all these layers of plastic. What is the number of a relay if anyone knows.
    I have VW GOLF MK4 TDI 90 BHP
    Engine code AGR
  2. Re: Where to find VW GOLF MK4 starter relay
    Apr 2007
    N.Ireland
    I take it you mean the glow plugs because diesels don't have spark plugs. Are you sure they're the actual problem, the flashing glow plugs light can mean any number of different things. Does the car start alright when cold?
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  3. Re: Where to find VW GOLF MK4 starter relay
    Dec 2007
    London(Middlesex)
    Just been around going to different garages even went to VW local dealer. (They asking for 70 pounds just to find whats the problem).
    Benn told buy another garage that it's a relay or when I was changing diesel pump and injectors, there is some sort of computer error which has to be cleared beucase computer in the car always for some reason thinking that my car is hot and thats why it's not starting in the mornings and when it's cold.
    Tommorow will order glow plug relay and see whats going to happened, if not going to help they will connect computer to reset a error.
  4. Re: Where to find VW GOLF MK4 starter relay
    Ireland
    take the layers of plastic away from under your steering wheel thats where the relays are. get a small garage that has vag-com to link it to the computer and tell you what faults come up it shouldnt cost more than £30 and it is cheaper than changing parts that might not need changed and the garage should turn off any lights that are on after you have changed the parts for no extra cost.
  1. How to Find if i have K jet or a Digifant golf GTI
    By Zelf1 in forum Golf MK2 - 1984 - 1992
    Last Post: 26-12-2007, 11:18 PM
  2. HELP! Where is my starter / ignition relay?
    By H18JGM in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2007, 11:53 PM
  3. how do i find out what BHP my mk4 golf TDI is?
    By kyleb in forum Archive posts
    Last Post: 31-10-2007, 12:29 PM
  4. HELP!! Golf VR6 Non starter
    By markjack in forum Golf MK3 - 1993 - 1999
    Last Post: 26-10-2007, 12:53 AM
  5. How do i find the sump plug 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 18-04-2007, 12:58 AM
