Thread: Throttle Potentiometer (G69) Passat B5.5
  1. Throttle Potentiometer (G69) Passat B5.5
    Hello,
    first i'am new, i'am from Romania, ( scuse me for english language )i'am a fan of VW grup.
    I have a VW Passat B5.5, from 2001, TDI, cod engine AVF.
    And i have a big problem from a long time ago. When a drive for long distance, my acceleration pedal dosent work. ABS and ESP leds lights, and the engine work to only 1100 rot/min, and acceleration pedal not response.
    I change acceleration pedal, i change the switch for a brake lights, but the problem dont resolve.
    I test my car whit a Vag-Com, and the result was :
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8D0 907 389 D
    Component and/or Version: ABS/ESP front D46
    Software Coding: 04255
    Work Shop Code: WSC 00028
    1 Fault Found:
    18264 - Throttle Potentiometer (G69): Error Message from ECU
    P1856 - 35-10 - - - Intermittent
    Control Module Part Number: 038 906 019 DS
    Component and/or Version: 1,9l R4 EDC 0000SG 1266
    Software Coding: 00002
    Additional Info: WVWZZZ3BZ1P061172 VWZ7Z0Y2998285
    1 Fault Found:
    18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
    P1639 - 35-00 - - - Intermittent
    Please help me if u have some ideas to change something for my car. Where is the Throttle Potentiometer G69 ?
    Thanks U.
    Robert
  2. Re: Throttle Potentiometer (G69) Passat B5.5
    Bumb.
    Some one can help me ?
    Thanks.
  3. Re: Throttle Potentiometer (G69) Passat B5.5
    Jun 2006
    UK, Mids
    Quote Originally Posted by RobertG View Post
    Bumb.
    Thanks.
    The throttle potentiometer is on the throttle body and measures the angle of opening of the throttle.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Throttle Potentiometer (G69) Passat B5.5
    can u help me whit a photo ? please ?
    thanks
  5. Re: Throttle Potentiometer (G69) Passat B5.5
    Jun 2006
    UK, Mids
    I don't know, a TDI doesn't have a throttle body. I just noticed teh date, have you had the problem for a year?
  6. Re: Throttle Potentiometer (G69) Passat B5.5
    Yes, i have a problem for a year...
  1. Error Code- Potentiometer for EGR?? Implausible signal ??
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2008, 09:57 PM
  2. is it a throttle problem???
    By pa o rahilly in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2007, 10:05 AM
  3. Throttle Control
    By willy100 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-08-2007, 08:36 PM
  4. Can I clear the fault codes with shareware VAG-COM?/Error Code- Potentiometer for EGR
    Last Post: 12-06-2007, 07:37 PM
  5. Throttle sticking when below 0
    By lilsarah in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2007, 10:49 AM
