Thread: Hard gear selection
  1. Hard gear selection
    Manchester, England
    Just wondering if someone can help with a problem i experienced this morning after leaving the motorway, i was travelling down to stoke and cruising along fine, came off the slip road into traffic and slowed down.
    Went to go into first gear, clutch pedal was fully depressed but it wouldnt slip into gear, i had to pratically ram it into first gear, this was the same going up to 2nd, 3rd etc and back down the gears as well.
    Managed to strugle to the office where i reversed into my space (went into reverse without a problem) I sat in the car for 5 minutes or so messing with the gear stick trying each gear but to no avail nothing would happen, then all of a sudden it would go into each gear fine.
    Just wondering if this is the start of anything or can it indicate any problems, or could it just have been something stuck in the gear mechanism?
  2. Re: Hard gear selection
    Manchester, England
    Gave it another go at lunch time and problem was worse than before, rang the RAC who are currently looking at it, he has diagnosed it to be the gear box, he said the oil was a little low so he was going to top that up, if not looks like the gear box is cream crackered and ill be getting a tow home
  3. Re: Hard gear selection
    Manchester, England
    gear box was completely devoid of oil it seems, RAC guy put in 2 litres and its now back to normal, just advised to get it checked over for any leaks etc.
    I am now very relieved that my baby is back on the road
  4. Re: Hard gear selection
    papabear Guest
    Hi mine has similar fault what oil do i put in.
  5. Re: Hard gear selection
    Sep 2009
    South Africa
    Replace the gearbox links(external of gearbox) that should be in the region of the same price tag as your lunch.
  6. Re: Hard gear selection
    Jan 2010
    kent
    Hi, i have been havng prob with my first gear. it wont go into first gear where first should be, i hav to push the gear stick down and half put into reverse to get first????????????? please help!!!!!!!!
    thnaks
  1. Mk3 TDi gear selection problems
    By ajs15 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-01-2014, 12:10 PM
  2. Sharan Gear Selection problem
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 08-05-2013, 03:13 PM
  3. Tight selection of gear box
    By Jeff72 in forum Passat - Archive Topics
    Last Post: 28-06-2007, 09:17 AM
  4. 2nd gear selection problem
    By hammill in forum Passat - Archive Topics
    Last Post: 25-06-2007, 09:55 PM
  5. Passat Gear Selection Stiff
    By chrisball666 in forum Passat - Archive Topics
    Last Post: 21-04-2007, 10:57 PM
