Thread: 1995 A4 Quattro - Heated rear screen switch
  1. 1995 A4 Quattro - Heated rear screen switch
    JDA Guest
    On my 1995 A4 Quattro, how is the switch for the heated rear screen removed from the dashboard?
    The switch is stuck in the on position & the heated rear screen is on all the time that the ignition is switched on.
  2. Re: 1995 A4 Quattro - Heated rear screen switch
    Nov 2005
    hi...
    ui think u hav to remove the surround 1st...dat will den giv u access too all the switches...(hazard,windscrn and the blank switch)
    to remove the panel, i used i thin blade flat screw driver...n carefully wedged it towards u...try aviod scratchin it...
    hope dis helps..
  1. Radio going with heated rear screen
    By andyroo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2008, 09:28 PM
  2. Mk4 heated rear screen problem
    By Arge in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2008, 12:53 AM
  3. Heated Rear Screen problem
    By davejcb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 04:26 PM
  4. heated front screen
    By Dozz in forum Passat - Archive Topics
    Last Post: 25-09-2007, 11:04 AM
  5. Passat B5 Heated rear screen & mirrors?
    By TDi_B5 in forum Passat - Archive Topics
    Last Post: 23-12-2006, 01:45 PM
