Thread: Can anyone help - A3 Coolant Leak & Oil Level
  1. Can anyone help - A3 Coolant Leak & Oil Level
    Jan 2008
    HI there, I have an A3 05 plate, 67K, recently, over the past month, i have had to top up the coolant level a couple of times. I took it to Audi for a Pressure test, they said that they could find no major leak. I am due to take it back in a few weeks for an overnight Ptest to see if they can find any small leak.
    However, today I have just checked the oil level and it is way up, over all of the markings by a 5mm. I have also noticed a smell of oil after a journey coming from the exhaust, Cat Converter, which would fit with such a high oil level.
    Is it possible for the coolant to be leaking into the engine and mixing with the oil?
    And what will be the impact of driving it until I can get it to the garage which could be a week?
    R
  2. Re: Can anyone help - A3 Coolant Leak & Oil Level
    Sep 2007
    yorkshire
    Quote Originally Posted by RussD View Post
    Yes, But if you are still driving the car, it will have gone creamy by now. Whats the underside of the oil-cap look like?
    2003 AUDI AVANT SPORT TDI
  3. Re: Can anyone help - A3 Coolant Leak & Oil Level
    Jan 2008
    The oil cap looks fine, as does the oil. no discolouration, although it seems thin. Although I am not totally sure how thick it should be.
  4. Re: Can anyone help - A3 Coolant Leak & Oil Level
    Sep 2007
    yorkshire
    If you are driving it, then it is not mixing with the oil. (oil and water mixing goes coffee coloured)
    When was the water-pump last changed? (if ever)
    Also you will get incorrect readings if you are not checking the oil the same way every time. i.e, always check a few mins after shut down on a full tempreture engine.
  5. Re: Can anyone help - A3 Coolant Leak & Oil Level
    Jan 2008
    The pump hasn't been changed.
    Thanks for the info, it could be the way that I checked it, It was cold.
    I am taking it to the garage to get it pressure tested on the 28th to try and find the leak. I was just racking my brain about the oil level and whether they were linked. I'll keep and eye on it and test the level as suggeted tomorrow.
    many thanks
    R
  1. A3 coolant leak
    By hensojm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2009, 12:22 PM
  2. mkv golf coolant level
    By Paul_mkV_golf in forum Golf MK5 - 2004 - 2009
    Last Post: 20-12-2006, 02:18 PM
  3. Golf MK3 Coolant Level & Temp Warning light
    By andyc567 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2006, 05:13 PM
  4. Coolant level
    By djsoftware in forum Passat - Archive Topics
    Last Post: 08-08-2006, 01:13 PM
  5. Check coolant warning but level fine
    By brad1 in forum Archive posts
    Last Post: 28-07-2006, 02:37 PM
