Thread: **Coolant Temperature Sensor**
  1. **Coolant Temperature Sensor**
    I'm new to this forum and hope I'm posting this in the right place, here's my scenario......After spending about 7K in repairs for the following parts in the past six months *Transmission rebuild, Cam Gasket Seals, Ignition Coil, Tie Rod Ends, ABS Control Module etc...I've discovered that I need to replace the Coolant Temperature Sensor. I have the sensor but cant get to it because there is a huge air intake tube (Hard Plastic) of somekind in the way and i found one screw at the top but its still being held on by another one! Is there anyone who can help me get this off???? (1998 Audi A4 2.8 V6) 104,000mi
    *I think it's called the Air Intake Duct** that I need to remove
  2. Re: **Coolant Temperature Sensor**
    May 2007
    Abingdon UK
    Hi, You have to remove this plastik hose. one end is fitted to air fillter cover and other end is fitted to throtlle body. good luck. regards Jocker01
  3. Re: **Coolant Temperature Sensor**
    Hi and thanks for your response, I got all of the air intake stuff off but I cant get the throttle body off. (Thad hard piece of plastic) There's one screw on top that I took out but there's still something connecting it??? Can't figure out how to remove it. Any advice???
  4. Re: **Coolant Temperature Sensor**
    May 2007
    Abingdon UK
    if I was You i will try do move that hose a bit on a site, That should be enough to remove this sensor (dual temperature sender 059919501 -this is part number) sensor is secure only by green clip and is easy to pull out, You may loose some collant, don't forget to remove from old one ruber ring and transfer to new one. I hope that will help You. Regards Jocker01
  5. Re: **Coolant Temperature Sensor**
    I'll try it tonight and let you know, thsnks!!
  1. A6 1.9 TDi coolant temperature sensor
    By PFPH in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-04-2008, 11:34 PM
  2. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  3. Low engine coolant temperature, which coolant to use
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 11:35 AM
  4. Coolant temperature sensor reading too high
    By vlad21 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 01:32 PM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
